B How to calculate torque on a body falling freely through the sky?
Calculating torque on a freely falling body involves understanding the axis of rotation, which is typically around the center of mass. When a force is applied at a distance from the center of mass, the torque arm is defined by the distance between the center of mass and the center of drag. The torque value varies based on the chosen reference point, and it can be calculated around any axis. For a mass falling from rest, if the origin is above the center of mass, the torque is zero, while a perpendicular distance from the trajectory results in a torque of τ = mgR. In free fall, any rotation will naturally occur around the center of mass unless other forces are applied.
pointdexter16
TL;DR Summary
if a body is pivoted at a point it is quite easy to calculate the torque as we know the axis of rotation. but, if a body is under free fall and we apply a force of F newtons at a distance of x from its centre of mass , then how do we determine the axis of rotation?
if a body is pivoted at a point it is quite easy to calculate the torque as we know the axis of rotation. but, if a body is under free fall and we apply a force of F Newtons at a distance of x from its centre of mass , then how do we determine the axis of rotation?
Welcome to PF.
The body will rotate about the centre of mass. As the body falls it also has an aerodynamic centre of drag. The distance between the centre of mass and the centre of drag, provides the torque arm that may cause the object to rotate.
Likes pointdexter16 and BvU
The torque depends on the point you choose to calculate it. It does not matter what the body does. The torque will have different values for different reference points (or axes). It's up to you to pick up a point that is convenient or useful for what you want to do with the values of the torque. But you can calculate it around any axis you want.
Likes pointdexter16 and andresB
The angular momentum of a body can be decomposed into two vectors: (a) angular momentum about the center of mass, more descriptively the spin angular momentum and (b) angular momentum of the center of mass, more descriptively the orbital angular momentum. Both vectors require a torque to change. A torque ##\vec \tau=\vec r \times \vec F## will have different effects depending on ##\vec r## which is the position vector from the origin to the point of application of the force.
Consider a fixed force ##\vec F## applied on a body. The question is, "what is the position vector ##\vec r~##? The answer is, "it depends on where you choose the origin." If you choose it at the center of mass of the object, its spin angular momentum will change in a direction perpendicular to the plane defined by the force and the position vector; its orbital angular momentum will not change. This is the situation described by @Baluncore in post #2. If you choose the origin about any point other than the center of mass, then both spin and orbital angular momentum will change in a way that depends on your choice.
Specifically, for a mass falling from rest, if you choose the origin directly above the center of mass, the angular momentum will not change about that origin which means, of course, that the torque will be zero. However, if you choose the origin at perpendicular distance ##R## from the straight line trajectory, the magnitude of the torque will be ##\tau = mgR## and the orbital angular momentum about the origin will vary in time according to ##L=mgtR##. If you tack on the mechanism suggested by @Baluncore, there will also be a change in the spin angular momentum.
Likes pointdexter16
Welcome!
Respect to the ground, anybody in free fall, if rotating, will naturally tend to rotate around its center of mass.
During the time an external force other than weight and drag is applied, the body is not free falling.
Likes pointdexter16
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
