How to certify that the proper legth of light is zero
Therefore, it doesn't have a rest frame and cannot have a proper length. In summary, the first problem is determining the proper length of light, which is not possible since light does not have a rest frame. The second problem involves using Lorentz transform to certify that the proper length of light does not change in all inertial frames.
DrHAO
I'm a new one on general relativity
there are two prolems:
first how to certify the proper length of light is zero
second ,how to certify proper length of light ,do not change in all inertial frame
for second question, probally Lorentz transform,
for the first
ds2=-c2dt2+dl2
dl/dt = 0
ds=0
I have no idea on Lorentz transform of delta s
DrHAO said:
... how to certify the proper length of light is zero
Proper length is the length of an object in its rest frame. Light doesn't HAVE a rest frame so doesn't have a proper length, unless you're using some different definition.
Yeah, from the moment a photon is created, it is instantly and always moving at c.
FAQ: How to certify that the proper legth of light is zero
What is the proper length of light?
The proper length of light is the distance that light travels in a vacuum in a given amount of time. This is typically measured in meters or kilometers, depending on the scale of the distance being measured.
How is the proper length of light determined?
The proper length of light is determined through various experiments and calculations, using principles from the theory of relativity. One common method is to measure the time it takes for a light pulse to travel from one point to another, and then using the speed of light to calculate the distance.
Can the proper length of light ever be zero?
In theory, the proper length of light can be zero in certain situations where light is traveling at the speed of light in a vacuum. This is known as "null length" and is a concept in Einstein's theory of relativity. However, in practical experiments, the proper length of light is never exactly zero.
How can we certify that the proper length of light is zero?
Certifying that the proper length of light is zero would require precise and accurate measurements of the speed of light and the distance traveled. This can be done through advanced equipment and techniques, but it is difficult to achieve absolute certainty due to the limitations of our current technology.
Why is it important to certify the proper length of light?
Certifying the proper length of light is important for understanding the behavior of light and its effects on the universe. It also plays a crucial role in various scientific fields, such as astronomy and physics, where precise measurements of distance and time are necessary for accurate calculations and predictions.
