CalcExplorer
- 4
- 1
Okay, so I'm working with a rather frustrating problem with a calculus equation. I'm trying to solve a calculus equation which I conceptualized from existing methods involving complex number fractal equations. I'm very familiar with pre-calculus, while being self-taught in portions of calculus for practical applications in coding and higher dimensional mathematics, so bare with me on this.
Here's the premise:
I'm using the Mandelbrot Equation [ z = z2 + i C ] and the Hausdorff Dimension [ N = sd ], where d = ln(N)/ln(s), to create a new iterational equation, which fractally conforms to an already defined Hausdorff Dimension [ log(20)/log(2+φ) ], where φ = ((√5)+1)/2. This specific Hausdorff Dimension is of a Dodecahedron Fractal Flake.
This provides the new equation:
z = zlog(20)/log(2+φ) + i C
I'm attempting to solve the first iteration of this new equation in quadratic form, the format the mandelbrot is solved in [ z2 = a2-b2 + 2abi ], as it's the format most advantageous for the graphical mapping of the fractal structure.
From what I've surmised thus far in order to solve such an equation I need to first convert the complex logarithm into a complex exponential using Euler's Formula, and then solve the new formula algebraically to derive the first iterational solution.
There seems to be a basis for this method, albeit with certain conditions in the solutions, and similar questions put up on this forum before, but I don't quite understand the principles enough to solve it myself.
These are the relevant mathematical references on the topic I've been able to find -
http://math.gmu.edu/~rsachs/m114/eulerformula.pdf
https://www.physicsforums.com/threads/eulers-formula-and-complex-logarithms-relationship.559665/
https://www.reddit.com/r/askscience/comments/2e3jnv/logarithms_of_complex_numbers_logarithms_with/
But that's pretty much it and I don't quite grasp how it's converted, since there's no direct examples of this process that I could find with conversions using Euler's Formula and Complex Logarithms.
Is this the proper way to go about solving such a problem?
And is there someone here that can help to find the solution?
Here's the premise:
