MHB How to Create 4-by-4 Magic Square w/Sum 34
  • Thread starter Thread starter soroban
    Magic Square
A straightforward method for constructing a 4-by-4 Magic Square involves filling the diagonal cells of a grid with sequential numbers from 1 to 16, starting from the upper-left and lower-right corners. This results in a Magic Square where the sum of each row, column, and diagonal equals 34. The construction highlights the inherent symmetry and patterns typical of Magic Squares, which have intrigued mathematicians for centuries. While this method is efficient and accessible, there are various other techniques for creating Magic Squares, including algebraic and algorithmic approaches, which can provide additional insights into their properties. This method serves as a practical solution for those interested in exploring the fascinating world of Magic Squares.
soroban
If you ever need a 4-by-4 Magic Square,
here's an easy way to construct one.
Draw a 4-by-4 grid
and consider the cells on the two diagonals.
$\quad\begin{array}{|c|c|c|c|} \hline
* &&& *\\ \hline
& * & * & \\ \hline
& * & * & \\ \hline
\hline \end{array}$Starting at the upper-left, count 1, 2, 3, ...
and insert the numbers in the diagonal cells.
\color{red}{1} &&& \color{red}{4} \\ \hline
& \color{red}{6} & \color{red}{7} & \\ \hline
& \color{red}{10} & \color{red}{11} & \\ \hline
\color{red}{13} &&&\color{red}{16} \\ \hline
\end{array}$Now start at the lower-right, count 1, 2, 3, ...
moving up the square, and insert the numbers.
1 & \color{red}{15} & \color{red}{14} & 4 \\ \hline
\color{red}{12} & 6 & 7 & \color{red}{9} \\ \hline
\color{red}{8} & 10 & 11 & \color{red}{5} \\ \hline
13 & \color{red}{3} & \color{red}{2} & 16 \\ \hline \end{array}$And there is the Magic Square!
Its magic sum is 34.
You will find "34" in various symmetric locations:
the 4 corner cells, the central 2-by-2 cells
the 2-by-2s in each corner, and so on.
Hello, thank you for sharing this easy method for constructing a 4-by-4 Magic Square! I find this type of problem-solving very interesting.
For those who may not be familiar with Magic Squares, they are a type of grid filled with numbers where the sum of each row, column, and diagonal is the same. In this case, the magic sum is 34. These types of puzzles have been around for centuries and have fascinated mathematicians and scientists with their patterns and properties.
Your method is a great way to quickly construct a Magic Square without having to rely on complicated mathematical formulas. It also highlights the symmetry and patterns that exist within the square, which is a common feature in Magic Squares.
I would also like to add that there are many other methods for constructing Magic Squares, some of which involve using algebraic equations or even computer algorithms. It's always interesting to explore different approaches and see how they compare.
Thank you again for sharing this method, I'm sure it will be useful for anyone looking to create a 4-by-4 Magic Square. Keep exploring and solving puzzles!
Thread 'RIP Chen Ning Yang (1922-2025)'
https://en.wikipedia.org/wiki/Yang_Chen-Ning ( photo from http://insti.physics.sunysb.edu/~yang/ ) https://www.nytimes.com/2025/10/18/science/chen-ning-yang-dead.html https://www.bbc.com/news/articles/cdxrzzk02plo https://www.cpr.cuhk.edu.hk/en/press/mourning-professor-yang-chen-ning/ https://www.stonybrook.edu/commcms/physics/about/awards_and_prizes/_nobel_and_breakthrough_prizes/_profiles/yangc https://www.stonybrook.edu/commcms/physics/people/_profiles/yangc...
Thread 'In the early days of electricity, they didn't have wall plugs'
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff! Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use? 1906 ad DDTJRAC Even big...
