Is It Possible to Create a Natural Vacuum in a Cavern Using Clay and Water?
In summary: I don't know, it's just a theory. If you could line a room or container with clay and then fill it with water, how long would it take for the vacuum to form?It would take a while. I'm not sure how long, but it would definitely take some time.
Liam A
i work at a cavern attraction and one of the parts in the speech we say is that a section of the cavern was once filled with a naturally occurring vacuum until it was punctured and destroyed. we explain in the speech that the vacuum was created when a river packed in that area with mud and clay. we say there were pockets of water trapped inside, and since clay is much like salt in that obsorbs moisture, the clay took the water out and there was nothing to replace it and therefore a vacuum formed. a few things i would like to know is:
a: how accurate and plausible this is.
b: if it could be recreated artificially, by for example lining or partially filling a container or room with clay and filling it with water.
c: how long the process would normally take if it is possible
d: and what the effects the vacuum would have on certain materials, specifically metal, wood, rust, or mold
Likes Merlin3189
That makes no sense- as the water drained out, the space was filled with air- or some sort of gas. What is your evidence that the cavern pressure was below atmospheric pressure for any length of time?
I think if most of the water was absorbed into the clay with no way for air to get it (an unlikely premise but conceivable), this would not create a vacuum, it would simply create a chamber that was filled with water vapor instead of liquid water
The clay should have been moist all the time if it was in contact with water.
I can imagine that very weird circumstances with just the right timescales could lead to some amount of water in dry clay which then quickly gets shut off from the remaining water. But even then I don't think the vacuum would get very good. Maybe a slightly lower pressure.
Related to Is It Possible to Create a Natural Vacuum in a Cavern Using Clay and Water?
What is a natural vacuum?
A natural vacuum is a space that contains no matter, including air molecules.
How can a natural vacuum be created?
A natural vacuum can be created by removing all matter from a given space, either through physical means such as suction or through chemical reactions that absorb or convert matter into other forms.
What are some potential applications of creating a natural vacuum?
Natural vacuums have many practical applications, including in space exploration, particle physics research, and the manufacturing of electronic components.
What are the risks associated with creating a natural vacuum?
The main risk associated with creating a natural vacuum is the potential implosion of surrounding materials due to the sudden change in pressure. This can be mitigated by using specialized equipment and following proper safety protocols.
Can a natural vacuum be sustained indefinitely?
No, a natural vacuum cannot be sustained indefinitely as matter will eventually enter the space through various means such as diffusion or leaks. However, it can be maintained for extended periods of time with the right conditions and maintenance.
13K
  • Mechanics
25K
25K
