How to deal with direction on impluse?
  • Thread starter KFC
  • Tags
    Direction
In summary, the conversation discusses the use of the impulse-momentum theorem in problem solving and the confusion around dealing with the direction of momentum. An example of a bullet hitting a hanging bar is given and the initial angular velocity of the bar is calculated using equations for conservation of momentum and angular momentum. The result is correct but the sign may differ depending on convention. It is noted that the impulse on the bullet is negative, meaning the impulse on the bar must be positive according to Newton's Third Law.
KFC
488
I am using impulse-momentum theorem in problem solving. But I am quite confusing about deal with the direction of momentum so always get the wrong sign.
For example, assume a long thin bar with mass M and length L hanging from a fixed frictionless point A at the ceiling, the bar is stay at rest. Now a bullet with mass m and initial velocity [tex]v_0[/tex] moving horizontally towards the bar and hit it at point B (the distance b/w A and B is y). Finally, the bullet embed into bar and then moving together with it. The instantaneous horizontal impulse when it hit the bar is [tex]I_b[/tex], find the intial angular velocity of the bar.
Since the system's total momentum is conserved, we can write
[tex]
mv_0 = (m+M)V_f
[/tex]
and the change of the momentum of the bullet is the impulse
[tex]
MV_f = -m(v_f-v_0) = -I_b
[/tex]
then the initial angular momentum of bar can be given by
[tex]
L = MV_f y = -I_b y
[/tex]
After collision, the bar (and the bullet) move around pivot A, the moment of inertia about A is [tex]I=ML^2/3[/tex] (ignore the mass of bullet). With the help of following equation
[tex]L = I\omega[/tex]
we find that
[tex]\omega = \frac{L}{I} = - \frac{3I_b y}{ML^2}[/tex]
the result (the value) is correct, but it should be positive. I have no idea where is the mistake come from.
Since the impulse on the bullet is negative, it follows from Newton 3 that the impulse on the rod must be equal but opposite, that is, positive. Bottom line, however, is that whether one calls [tex] \omega [/tex] positive or negative, it's rather a question as to whether the rotation is clockwise or counterclockwise. The sign choice is largely a matter of convention.
Thanks
FAQ: How to deal with direction on impluse?
What is direction on impulse?
Direction on impulse refers to the direction in which an object is moving after experiencing an impulse, which is a change in momentum caused by a force acting on the object. It is an important concept in understanding the motion of objects.
How can I determine the direction on impulse?
The direction on impulse can be determined by using the principle of conservation of momentum. This states that the total momentum of a system remains constant unless an external force acts on it. Therefore, the direction on impulse can be determined by analyzing the initial and final momenta of the object.
How does the direction on impulse affect the motion of an object?
The direction on impulse affects the motion of an object by changing its velocity. If the impulse acts in the same direction as the initial velocity, the object will speed up. If the impulse acts in the opposite direction, the object will slow down. The change in direction also affects the object's trajectory, causing it to deviate from its original path.
What factors can influence the direction on impulse?
The direction on impulse can be influenced by the magnitude and direction of the force acting on the object, as well as the mass and initial velocity of the object. Other factors such as external forces and friction can also affect the direction on impulse.
How can I apply the concept of direction on impulse in real-life situations?
The concept of direction on impulse has many practical applications, such as in sports, where players need to change direction quickly to avoid obstacles or opponents. It is also important in engineering, where understanding the direction on impulse can help in designing efficient and safe structures. Additionally, it is crucial in understanding the motion of celestial bodies in space.
