chrisAUS
- 3
Let h be an observed value at a given time t
t = 5, 10, 20, 30, 40, 50
h = 0.72, 0.49, 0.30, 0.20, 0.16, 0.12
Let h* be a modeled estimate of h
h* = [ Q / 4*Pi*T*t ] * e [ - (d^2)*S / 4*T*t ]
where the known constants are Pi, Q (= 50), and d (= 60)
and the values of the two parameters T and S are unknown.
Values of T and S can be estimated through the minimisation of the sum of squared differences between h and h* over all times.
The adjoint method involves formulating a function (e.g. H) which is composed of the sum of the function of interest (i.e. in this case, h*) and a second term, which is composed of a Lagrange multiplier multiplied by a constraint function.
How do I formulate the constraint function? I'm guessing that it should involve the squared difference between h and h*, since the minimisation of (h-h*)^2 is the desired outcome. But, since there are 6 times at which h* is calculated, will I need to have 6 formulations of H (and therefore 6 different Lagrange multipliers)? Or, since the minimisation of the sum of (h-h*)^2 for all times is the overall desired outcome, do I only need to formulate one equation for H?
Another point that bothers me is this. In the examples of the use of the adjoint method that I have seen, the constraint function is formulated in terms of the parameters of interest (i.e. in this case, T and S), rather than in terms of the function of interest (i.e. in this case, h*).
Thanks in advance.
