I How to define an open set using the four axioms of a neighborhood
  • I
  • Thread starter Thread starter learning physics
    General topology
learning physics
TL;DR Summary
How do I use the four axioms of a neighborhood to define an open set?
I am struggling to define an open set using the four axioms of a topological neighborhood, as per the Wikipedia article "Topological spaces."
An open set on a real number line is a set of points that contains only interior points, meaning that there is always room for some hypothetical particle to move either side of each point. Let's call this "the intuitive definition" of an open set.
An open set is defined as a neighborhood of all of its points, but I don't see how that would connect to the intuitive definition.
If a set of points is a neighborhood of all of its points, which we'll call The Large Neighborhood, it means that each point is contained in a neighborhood even smaller than The Large Neighborhood, which we'll call "small neighborhoods." Each point in The Large Neighborhood must also be contained in a neighborhood even smaller than the small neighborhoods, and so on. So, each point in The Large Neighborhood is buried underneath an infinite number of neighborhoods that are smaller than The Large Neighborhood. Still don't see how this connects to the intuitive definition.
Anyone care to help?
You could try this guy's YouTube series:
learning physics said:
TL;DR Summary: How do I use the four axioms of a neighborhood to define an open set?
State this formally: U \subset \mathbb{R} is open if and only if for each x \in U there exists \delta > 0 such that (x - \delta , x + \delta) \subset U. (You can move up to \delta away from x in either direction without leaving U.)
(x - \delta, x + \delta) is a neighbourhood of x.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
