A How to define ##\nabla \cdot D ## at the interface between dielectrics
Maxwell's equations can describe electromagnetic effects at the interface between two dielectrics with distinct permittivities, where the normal component of the electric displacement field D is continuous, while the electric field E shows discontinuity. The challenge arises when attempting to define the divergence of D at interfaces involving three or more dielectrics, particularly at edges and vertices, where singularities complicate the situation. Standard methods, such as using Gaussian surfaces, help establish continuity conditions but fall short in these complex scenarios. The discussion emphasizes the need for a generalized approach to handle these singularities, focusing on surface divergence and curl. Ultimately, defining divergence at such interfaces remains a significant challenge in electromagnetic theory.
coquelicot
TL;DR Summary
Defining ##\nabla \cdot D## or ##\nabla \cdot E## at the interface between dielectrics
It is believed that Maxwell equations (together with other relations depending on the materials) are sufficient to account for any electromagnetic macroscopic effect.
The problem is that, for a Maxwell equation to hold, it must at least be defined.
Consider for example the case of two dielectrics of distinct permittivities, say ##\epsilon_1## and ##\epsilon_2##. We assume for the sake of simplicity that ##D_{conductor 1} = \epsilon_1 E_{conductor 1}## and ##D_{conductor 2} = \epsilon_2 E_{conductor 2},## which already covers a lot of dielectrics.
We also assume that the dielectrics carry no free charge, so Maxwell equation reads ##\nabla \cdot D = 0##.
Let finally restrict ourselves to the electrostatic case.
If the two dielectrics interface at a surface S, then the normal component of E is discontinuous at S, its tangential component is continuous, while the normal component of D is continuous and the tangential components of D are, in general, discontinuous.
For the field E, we could define ##\nabla \cdot E## using the Dirac distribution.
I guess something like that is possible for defining ##\nabla \cdot D##, despite I don't see exactly how (the difference between E and D is that E has only one discontinuous component).
Now, even if a Dirac distribution artifice is possible whenever the interface between two dielectrics is a surface, I see no way to define ##\nabla \cdot E## or ##\nabla \cdot D## whenever three or more dielectrics interface at an edge, or whenever several dielectric interface at a vertex point.
Any idea/knowledge to save Maxwell equations?
At boundaries of two media you have to apply the integral definition of the differential operators, possibly generalized to their forms describing discontinuities. If you have no free charge, i.e., ##\vec{\nabla} \cdot \vec{D}## using a Gaussian pill box with two of its surfaces parallel to the boundary tells you that the normal component of ##\vec{D}## is continuous, while the normal component of ##\vec{E}## is not. That's because there's a non-zero net-surface charge along the boundary, because of the different polarizability (permittivities) in the different media. from ##\vec{\nabla} \times \vec{E}## using a surface with two sides parallel to the boundary and using Stokes's integral theorem tells you that the components tangential to the boundary are continuous.
Thanks for your answer.
Yes, that's classic and I wrote that in the question too. Not of any help to define ##\nabla \cdot D## at the interfaces between several dielectrics unfortunately.
If you have a singularity at the surface, of course, you can't define a quantity on the surface. You have to describe what happens at the surface by describing the corresponding singularities, i.e., in this case by the surface divergence and surface curl.
Actually the problem is not surfaces but edges and vertices. The essential point in my question is contained in the last 3 lines.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
