How to define the rotation of a planet in retograde orbit?
In summary, retrograde/prograde rotation refers to the object's rotation compared to its own orbital direction, regardless of whether that orbit is retrograde or prograde. The perspective of the observer and the reference frame used can also affect the perception of retrograde and prograde rotation.
Alltimegreat1
115
If a planet is in retrograde orbit, what direction would it rotate to also have retrograde rotation?
Astronomy news on Phys.org
If it is orbiting anticlockwise around an object which is rotating clockwise, then assuming by retrograde rotation in relation to the motion around that central object, I would suggest it too would rotate clockwise.
Likes Beduino
Actually this is a bit tricky question because it depends on the observer, if you are above the "north" pole looking below, or below the south pole looking above, but I suppose it would the reverse or negative of whatever you consider prograde rotation.
Likes Bujon
Assuming the OP might be assuming the axis of rotation of the planet is in the same plane as that of the central object? And that the perspective is from a relative viewpoint to both.
The sun rotates counter-clockwise as viewed from above looking down at its north pole. Let's assume one of its planets orbits the sun clockwise (retrograde) and also rotates clockwise. Is this planet's rotation prograde or retrograde?
I would say its rotation would be retrograde in relation to the rotation of the sun, but prograde in relation to its own orbital rotation of the sun
Actually let's compare with the Earth, from above north pole it rotates counter clock wise around itself and around the sun. So the retrograde is the opposite of both.
So yes that is retrograde.
So does that mean that retrograde/prograde rotation refers to the object's rotation compared to its own orbital direction, regardless of whether that orbit is retrograde or prograde?
See it depends on several things, is Earth your reference frame? How do you define the north pole of a planet? so on...
Also this notion of prograde or retrograde around itself gets really confusing if the planet axis inclination goes to 90 degrees compared with everything else, but again retrograde is going to be the negative of whatever you have considered prograde.
Likes Bujon
I could be wrong, but my common sense approach is you have to define with what you are relating the observation. You could be retrograde to the spinning rotation of an object, but prograde to your own orbital path around that object, irrespective of the central objects spin?
Yes it is a bit confusing, but we should try to get to the bottom of this. To make things easier, let's assume all objects in the solar system have no axial tilt. If our Earth, which has both prograde orbit and rotation, suddenly started orbiting in the opposite direction but retained its current rotational direction, it would have a retrograde orbit but a rotation that is prograde compared to the sun but retrograde compared to its own orbit.
Alltimegreat1 said:
https://en.m.wikipedia.org/wiki/Retrograde_and_prograde_motion The part about the Uranus moons explains it I think. Uranus had retrograde rotation, and its moons rotate the same way Uranus does, meaning the moons have prograde rotation compared to Uranus and retrograde rotation compared to the sun.
Again it brings you back to relativity in the sense of where you are looking and from what you are measuring against.
Related to How to define the rotation of a planet in retograde orbit?
1. How is the rotation of a planet defined?
The rotation of a planet is defined as the spinning motion of a planet around its own axis. This axis is an imaginary line passing through the center of the planet and connecting the north and south poles.
2. What is a retrograde orbit?
A retrograde orbit is when a planet or other celestial body orbits in the opposite direction of the majority of planets in the solar system. In other words, it orbits in a clockwise direction instead of the typical counterclockwise direction.
3. How is the rotation of a planet in retrograde orbit measured?
The rotation of a planet in retrograde orbit is measured by the length of its day, or the amount of time it takes for one full rotation on its axis. This can be determined by observing the planet's surface features or by using advanced imaging techniques.
4. What factors can cause a planet to have a retrograde orbit?
There are several factors that can cause a planet to have a retrograde orbit, including gravitational interactions with other planets, collisions with other objects, and tidal forces from a nearby large body.
5. Can a planet's rotation change from direct to retrograde orbit?
Yes, a planet's rotation can change from direct to retrograde orbit. This can happen due to external factors such as collisions or gravitational interactions, or internal factors such as changes in the planet's mass distribution or internal structure.
  • Astronomy and Astrophysics
