How to describe the 4th dimension?
In summary, the 4th dimension is time, and it is described mathematically in the same way as the spatial dimensions in 4-dimensional spacetime. The negative sign in front of the dt^2 term is a convention that allows for the units to match up and preserves the invariance of the line element. This convention is important because it distinguishes 4-dimensional spacetime from 4-dimensional euclidean space and allows for the calculation of different types of events based on the interval.
Rico L
37
what is 4th dimension? is it just 1 dimensional space? how come time is described as the 4th dimensional path?
thanks..
how to describe it? in a mathematical way pleasez... :)
Depends on how you define the 4th. In relativity we say fourth simply because this theory (in its most basic version) only includes 3 spatial dimensions so the natural addendum is to put time as the 4th. In reality, we treat it more like its the zeroth dimension, which is probably more correct. To deal with this time mathematically, here is a snippit:
In flat 3-dimensional space, the infinitesimal distance between any two points is given (in cartesian coordinates) by:
[tex]ds^2=dx^2+dy^2+dz^2[/tex]
Which you might recognize as simply the infinitesimal form of the familiar Pythagorean theorem. In a flat 4-dimensional spacetime, the new expression is:
[tex]ds^2=-dt^2+dx^2+dy^2+dz^2[/tex]
Note how this is not the simple Pythagorean theorem because of the sign change! (The negative on the time part is merely convention. What is important is the time component has a different sign from the spatial component) So time enters into the calculation of the distance between any two points, so that the resulting path is made up of the temporal and spatial displacements according to the above form.
but why x, y,z and t has to be squared? i take this chance to ask another similar question as well.. why C has to be squared in E=MC^2 ... and when you calculate kinetic energy.. E=half MV^2... why squared?
As far as the velocities: for one thing, it makes the units work out. For another thing, those particular formulas can be successfully used to calculate experimental results. Why, did you think it should be something else?
The reason that the x, y, z, and t are squared in the line element equation Nabeshin posted is completely different. That has to do with the Pythagorean theorem. In 3D space, we observe that the formula
[tex]\Delta s^2 = \Delta x^2 + \Delta y^2 + \Delta z^2[/tex]
allows us to calculate the distance between two points, and similarly in 4D space the formula
[tex]\Delta s^2 = -\Delta t^2 + \Delta x^2 + \Delta y^2 + \Delta z^2[/tex]
allows us to calculate the "interval" between two points, which is a useful quantity (it tells you whether a particle could get from one point to the other).
You just use R^4 instead of R^3.
Sorry, I know you said it's convention but why? I mean I understand why in Newtons law of gravity, there is a negative in front of GMm/r^2, but you haven't really explained why this convention and what the importance of having a negative in front of the dt^2 is.
Ok one thing I forgot to mention in my first post that I will say now. I implicitly was using units where c=1. If you do not set c=1, the equation is:
[tex]ds^2=-c^2 dt^2 +dx^2 +dy^2+dz^2[/tex]
Now you can see the units all match up (they're all units of length squared). Sorry if that confused anyone.
As for why the time component has an opposite sign, do you want a rigorous derivation? A hand-wavy argument is that we really want ds2 to be an invariant quantity. If the signs were all positive, then the line element would not be invariant. Perhaps you can come up with an example to convince yourself of this.
It's importance, though, cannot be understated. The fact that the sign is different shows us that this spacetime is NOT simply 4-dimensional euclidian space, where we would expect:
[tex]ds^2=dw^2+dx^2+dy^2+dz^2[/tex]
Also, in the euclidian scheme the interval is always greater than or equal to zero. With minkowski space (the -dt^2 one has this name), however, we can have an interval which is positive, negative, or zero. Perhaps you have heard of this, as these intervals correspond to the three different classes of events. With the convention I am using (-,+,+,+) it goes like this:
ds2>0: This means the spatial component (dx2 +dy2 +dz2) is larger than the time component. What this physically means is that these two points in spacetime are causally disconnected. That is, one could not possibly have caused the other, as to do so a signal would have had to have traveled faster than the speed of light.
ds2=0: This is the world line for light, where the spatial component equals the time component. Objects with this interval are only causally connected for interactions with massless particles (which necessarily travel at the speed of light).
ds2<0: These are time-like world lines, and indicate causal events. People, footballs, and anything with mass will follow a world line like this.
So you see, a lot of structure comes out of that one simple minus sign!
Hopefully I have answered your question okay, sorry I can't think of a slicker way of explaining the origins of the sign difference though. Perhaps someone else can help me out there.
I'm not sure where you want to go with this line of questioning, but you are asking about something that is simply a word we use to describe a mathematically useful relationship. It's just a definition.
But for the relationship itself, work is force times distance and kinetic energy is easily derivable from work: Consider the work required to create some potential energy by lifting a rock, then converting it to kinetic energy by dropping it.
It took a couple of reads to understand till it made perfect sense. The only thing that I don't quite see the importance of is:
Why is it important that ds2 be invariant? And also why the c2 is attached to the dt2. As effectively the product of this is a speed and a time, so hence a distance. Which does make sense in it's self. But why not just right this product as a distance?
Si
PS. Can you direct me to where you have all the nifty codes for writing squared and other signs? Much appreciated.
What we are looking for is something in spacetime geometry (aka Minkowski geometry) which is analogous to distance in Euclidean geometry. In Euclidean geometry distance is invariant under rotations and translations. The equivalent class of operations in spacetime is spatial translations, spatial rotations, time translations, and boosts (relative velocity). So we are looking for something which is invariant under those operations, this thing will be the spacetime analog to spatial distance.
Oh ok, that makes sense. Thanks for clearing that up Dale.
I'm not quite sure what you mean "why not just write this product as a distance", but the point is it makes no sense to add quantities with different units. When you actually derive the form of the interval you see the c2 there, but in relativity we generally use units where c=G=1, so I tend to forget about factors of c and G and insert them back so at the end. Can seem a bit haphazard to someone not familiar with using geometric units, so I apologize for that.
https://www.physicsforums.com/showthread.php?t=386951
Cheers!
this is amazing!
thanks a lot people! :P
just 1 last question.. what does the s of ds^2 stands 4?
and the t stands 4 time ?
thanks
The s stands for arc length or distance.
oh.. cheers
Related to How to describe the 4th dimension?
1. What is the 4th dimension?
The 4th dimension is a mathematical concept that represents a space beyond the three dimensions of length, width, and height. It is often referred to as the dimension of time.
2. How is the 4th dimension different from the other dimensions?
The 4th dimension is different from the other dimensions because it is not a spatial dimension like length, width, and height. Instead, it represents the concept of time and allows for movement and change over time.
3. How can we visualize the 4th dimension?
It is difficult for humans to visualize the 4th dimension as our brains are only capable of perceiving three dimensions. However, we can use mathematical models and visual aids, such as tesseracts (4D cubes), to help us understand the concept.
4. What is the significance of the 4th dimension in physics?
The 4th dimension is crucial in many physics theories, such as Einstein's theory of relativity and the concept of spacetime. It helps us understand the relationship between space and time and how they affect the movement of objects.
5. Can we travel through the 4th dimension?
As of now, there is no evidence to suggest that humans can physically travel through the 4th dimension. However, some theories, such as the concept of wormholes, suggest that it may be possible to travel through the 4th dimension in the future.
  • Other Physics Topics
20K
