How to Determine Electric Flow Through a Square Surface Due to a Nearby Charge?
In summary, the conversation discusses determining the electric flow through a square surface of side 2l due to a load + Q located at a perpendicular distance l from the center of the plane. The participants consider using Gauss's law and taking advantage of symmetry to simplify the calculation. It is suggested to apply Gauss's law to a cube with the assumption that the Y-axis passes through the center of the square. The conversation concludes that this approach is likely to be successful.
Est120
54
determine the electric flow through a square surface of side 2l due to a load + Q located at a perpendicular distance l from the center of the plane
I really don't know how to answer this question .i need help guys
Thanks
I ended up with a doble integral ,which i had to evaluate in order to calculate the flow of electric fiele in the whole square
Can you share the details of the the work you've done so far? Is there a figure that accompanies the problem that you can upload?
this would be the image ,and i tried this:
im new to this kind of things also English is not my principal language
You may not need to do an integration for this. Take advantage of the symmetry
Likes gneill
Should i just apply Gauss law And multiply by 1/6 ?
If you can assume that the Y-axis passes through the center of the square so that symmetry is preserved, then yes.
The question will be, what is the closed surface on which you are applying Gauss's law, before dividing by 1/6?
A cube ,but i don't know if it's as easy as that
Actually, it is as easy as that! (With the assumption described in post #6).
I would say, just go ahead and try it.
Related to How to Determine Electric Flow Through a Square Surface Due to a Nearby Charge?
1. What is Gauss' Law?
Gauss' Law is a fundamental law of electromagnetism that relates electric charges to the electric field they produce. It states that the electric flux through a closed surface is equal to the net electric charge enclosed by that surface.
2. How is Gauss' Law applied to determine the electric flow through a square surface?
To apply Gauss' Law to determine the electric flow through a square surface, we first draw a Gaussian surface which is a closed surface that encloses the square surface. Then, we calculate the net electric charge enclosed by the Gaussian surface and use the formula Q/ε0 to find the electric flux.
3. What is the formula for determining the electric flow through a square surface using Gauss' Law?
The formula for determining the electric flow through a square surface using Gauss' Law is E*A = Q/ε0, where E is the electric field, A is the area of the square surface, Q is the net electric charge enclosed by the Gaussian surface, and ε0 is the permittivity of free space.
4. How is the direction of the electric field determined in a Gauss' Law problem?
The direction of the electric field in a Gauss' Law problem is determined by the direction of the electric flux through the Gaussian surface. If the net electric charge enclosed by the Gaussian surface is positive, the electric field points outward from the surface. If the net electric charge is negative, the electric field points inward towards the surface.
5. Can Gauss' Law be applied to any shape of surface?
Yes, Gauss' Law can be applied to any closed surface, regardless of its shape. However, it is easier to apply to surfaces with high symmetry, such as spheres, cylinders, and cubes, as it simplifies the calculation of the electric field and flux.
