How to determine phase constant?
In summary, the problem involves a 225g mass attached to a horizontal spring oscillating at a frequency of 4.00 Hz. At t=0s, the mass is at x = 5.00 cm and has v_x = -37.0 cm/s. The phase constant is determined using the equations for velocity and SHM, and the result is found to be 106.40º or 1.857 radians. When calculating the position at t = 5.00s, the correct formula to use is x=Acos( ωt + ϕ) with ϕ=0.2893...
Bigworldjust
54
A 225g mass attached to a horizontal spring oscillates at a frequency of 4.00 Hz. At t=0s, the mass is at x = 5.00 cm and has v_x = -37.0cm/s . Determine the phase constant.
velocity = v(t)
v(t) = Aω·cos( ωt + ϕ )
-37 cm/s = ( 5.2122*10^-2 m )( 25.133 rad/sec )cos( 0 + ϕ )
-0.282 = cos( ϕ )
ϕ = cos⁻¹( -0.282 )
ϕ = 106.40º = 1.857 radians ◄---
However that answer is wrong, and I am not sure why. Can anyone help?
The result is correct, but you could have used both x(0) and v(0) to calculate the tangent of the phase constant, and decide about the quadrant by examining the sign of the sign and cosine.
It is possible that the SHM was defined as x(t)=cos(ωt + ϕ). Try it. ehild
So instead of using -37 use 5 instead? I tried that and got 1.5324 radians and it's still wrong, lmao. Hmm..
How did you get 1.5324 radians?
If x=Acos(ωt+φ), v=-Aωsin(ωt+φ), X(0)=5=Acosφ, v(0)=-37=-Aωsinφ:
tanφ=7.4/(8π)...
Both sine and cosine are positive so the angle is in the first quadrant.
ehild
Ah, thanks I see where I made the error. It was .2863rad. Thanks alot!
Actually now I am having trouble with the last part, lol. The question is to determine the position at t = 5.00s .
I did this:
Position = s(t)
= A·sin[ ωt + ϕ ]
= ( .052122 m )sin[ (25.133 s⁻¹)( 5.0 s ) + .2893 ]
And got .01478 m, but that is wrong. Any help?
But we have figured out that the position was x=Acos( ωt + ϕ) with ϕ=0.2893...
ehild
ehild
Wow, I didn't even realize, hah. Thanks again for all the help!
Related to How to determine phase constant?
1. What is the definition of phase constant?
The phase constant is a value used in the mathematical representation of a periodic wave to indicate the position of the wave relative to a reference point. It is measured in radians and represents the starting point of the wave.
2. How is phase constant related to phase shift?
The phase constant and phase shift are two ways of representing the same concept. The phase constant is the initial value of the phase shift, and it is used to calculate the phase shift at any given point in time.
3. What is the difference between phase constant and frequency?
The phase constant and frequency are two different parameters used to describe periodic waves. The phase constant represents the starting point of the wave, while the frequency represents the number of complete cycles of the wave per unit time.
4. How do you calculate the phase constant?
The phase constant can be calculated using the formula ϕ = 2πf₁, where ϕ is the phase constant, f is the frequency, and ₁ is the time at which the phase is measured.
5. Can the phase constant change over time?
Yes, the phase constant can change over time if the wave is subject to external forces or if it interacts with other waves. In a stable system, the phase constant remains constant, but in a dynamic system, it can vary over time.
11K
