How to determine the force in hadron decays
In summary: Thank you! This was very helpful, I hope that replying to this did not inconvenience you in any way.No worries at all. I'm glad it helped!
Jayrokk
I was wondering if someone could explain to me how you determine how a Baryon/Meson decays, meaning Strong decay, Weak decay, and Electromagnetic decay. Or if you could simply link me to a chart with a list of all of the forces they use to decay (if such a thing exists, I can't find one) it would be much appreciated. I know that neutral Pion decays electromagnetically, and that the charged pions and the neutron and a few others decay weakly, but I would very much like the rest. Thank you.
So the easiest way to do this is by looking at the particles involved, and knowing how different particles interact. For example, if you see a neutrino, you know immediately that it was a weak decay, eg:
π+ -> π0 + e+ + ve
Because neutrinos only interact with the weak force.
Similarly, you know that this
Z0 -> e+ + e-
must be weak, because Z0 is neutral and non-composite, so no EM, and electrons don't feel the strong force.
However,
π0 ->e+ + e-
May be EM or weak, but strong is forbidden (same as above), however weak is less probable in this instance, because of the timescales of the reactions - τEM=10^-16s, τweak=10^-10s. This is true in general. If it can go by strong, it will mostly go by strong, and so on.
Anything that involves a γ must be a EM interaction, because γ feel the EM interaction.
Anything with a flavour change must be from a weak interaction, because it is the weak interaction that changes flavour, for example
D+-> K- + π+ + π-
(The easiest way to see that is to write out the quarks).
What about something like
[itex]p + \overline{p} \rightarrow \pi^+ + \pi^-[/itex]?
In this case, it is not forbidden by the strong force, therefore most of the time it will happen by the strong force.
By the way, this is from something called the Totalitarian Priniciple that states that any decay that is not forbidden must occur. In this way, you can uncover new conservation rules - if a reaction doesn't happen, you have to figure out why.
Thank You so much! This was very helpful, I hope that replying to this did not inconvenience you in any way.
No worries at all. I'm glad it helped! This is something I teach, so it's pretty well stuck in my head.
e.bar.goum said:
Z0 -> e+ + e-
It is weak by definition since the Z is a mediator of the weak force and therefore must have at least one weak vertex.
Or it just happens too rare for the current experimental precision. Prominent examples are the decays of neutral mesons to two muons. It is easy to write down Feynman diagrams for their decays, it is easy to search for two muons - but the decays are so extremely rare (a few decays in a billion, or even less) that it is hard to see them at all.
Yeah, totally. That's why you do those rare searches - if you can't find the decay, you need a good reason.
As a bit of an aside, another cool example is neutrinoless double beta decay. That's some hardcore experiments right there. Although I'm not sure I like the idea of spending my career not finding things!
Or, if we are on the topic of not finding things: proton decay.
is proton decay predicted by the Standard Model?
I think it's not...
Yeah, protons are stable in the Standard model due to Baryon number conservation.
The search for proton decay is motivated by BSM models that predict the violation of baryon number conservation, but instead say that the Baryon-Lepton number (B-L number) is conserved.
(The reason you invoke B-L conservation is that unlike B conservation, the symmetry would not be broken by chiral or gravitational anomalies, if the symmetry is global)
This also goes for neutrinoless double beta decay. In the SM, lepton number is also conserved (on the perturbative level).
In the SM baryon number is broken by non-perturbative effects and the accidental symmetry is B-L. This is the basics underlying electroweak baryogenesis (ok, that does not work, but it would have been the basics if the parameters were more favorable ...) and part of the reason baryogenesis via leptogenesis is a possibility.
I guess that's why some people consider the Majorana nature of neutrinos to be an extension to the Standard Model (of course this is playing with words and definitions-what you define as SM-)... However double beta decay with neutrinos is a SM process.
Either Dirac or Majorana masses are typically considered an extension of the SM. Neither can actually be assumed as standard as we do not know which one is true. Double beta decay does not violate neither B or L and is therefore fine within the SM.
I stated for Majorana nature of neutrinos. In case we can measure a [itex]0v \beta \beta[/itex] decay this would imply that neutrinos are their own antiparticles, so they would satisfy the Majorana condition something the Dirac neutrinos don't have to...
the [itex]2v \beta \beta[/itex] decay is indeed not violating any of those symmetries and thus is fine within SM...
Related to How to determine the force in hadron decays
1. What is a hadron decay?
A hadron decay is a process in which a subatomic particle called a hadron, such as a proton or neutron, breaks down into smaller particles. This process is governed by the strong nuclear force, which is one of the four fundamental forces in nature.
2. How is the force in hadron decays determined?
The force in hadron decays is determined by analyzing the decay products and their properties, such as momentum and energy. This information is then used to calculate the forces involved in the decay process.
3. What are the tools used to study hadron decays?
Scientists use particle accelerators, such as the Large Hadron Collider, to produce high-energy collisions between particles and study the resulting decay products. They also use detectors to measure the properties of the decay products.
4. How does the strong nuclear force play a role in hadron decays?
The strong nuclear force is responsible for holding together the quarks, which are the fundamental particles that make up hadrons. During a hadron decay, the strong nuclear force is overcome, causing the hadron to break apart into its constituent quarks or other particles.
5. Why is it important to study hadron decays?
Studying hadron decays allows scientists to understand the fundamental forces and particles that make up the universe. This knowledge can lead to a deeper understanding of the laws of nature and potentially new technologies or applications in fields such as medicine and energy.
