How to determine the number of supercharges (N) for any dimension (D)?
  • Thread starter Osiris
  • Tags
    Dimension
In summary, the number of supercharges, or \thetas, for arbitrary dimension can be determined by the maximum supersymmetry algebra that does not raise the spin above 1 for theories without gravity and above 2 for theories with gravity. The organization of supercharges also depends on the spinor structure of the dimension, and this reasoning can also explain the presence of a maximum dimension for the supersymmetry algebra.
Osiris
e.g.
For D=11, the M-theory, we require N=8, ...
For D=10, we require N=16, or 32...
So how to determine the number of supercharges, the [tex]\theta[/tex]s, for arbitrary dimension, e.g. D=1, 2, ...
Hi Osiris,
Do you mean, how do you determine the maximum number of supercharges? If so, the intuitive answer comes from restricting the spin of particles in the supermultiplet. Generically, the supercharges raise or lower the spin of the particles in a supermultiplet. The maximum number of supercharges is determined by the largest supersymmetry algebra that doesn't raise the spin above 1 for theories without gravity or above 2 for theories with gravity. Note also that the counting can be bit funny because the way you organize the supercharges depends on the spinor structure of the dimension you're in. This sort of reasoning can also be used to understand the presence of a maximum dimension for the supersymmetry algebra.
Related to How to determine the number of supercharges (N) for any dimension (D)?
1. How do you calculate the number of supercharges (N) for a given dimension (D)?
The formula for determining the number of supercharges for a given dimension is N = 2^(D/2). This formula is derived from supersymmetry, a theoretical framework in particle physics that relates bosons (particles with integer spin) and fermions (particles with half-integer spin).
2. What does the number of supercharges (N) represent in a supersymmetric theory?
The number of supercharges (N) represents the amount of supersymmetry present in a supersymmetric theory. This number determines the symmetry and properties of the theory, and can range from 0 to infinity.
3. Why is it important to determine the number of supercharges in a supersymmetric theory?
Determining the number of supercharges is important because it helps us understand the underlying symmetries and properties of a supersymmetric theory. It also allows us to make predictions about the behavior of particles and interactions within the theory.
4. Are there any experimental methods for determining the number of supercharges?
No, there are currently no experimental methods for determining the number of supercharges in a supersymmetric theory. This number is typically determined through theoretical calculations and is not directly measurable.
5. Does the number of supercharges change for different dimensions?
Yes, the number of supercharges (N) changes for different dimensions (D). As mentioned earlier, the formula for calculating N is N = 2^(D/2), so as the dimension increases, the number of supercharges also increases. This is due to the fact that higher dimensions allow for more degrees of freedom and symmetries.
  • Beyond the Standard Models
  • Quantum Physics
