How to determine the product of a Chemical Reaction.
In summary, the conversation discusses the rules for balancing chemical equations and determining the products of reactants. It explains that when reacting with cold water, a metal hydroxide is produced, while an oxide is produced when reacting with steam. The example equation of Ca + H2O is balanced by Ca(OH)2 + H2, not CaO + H2, due to the charge of calcium and the formation of OH(-) as the anion. The same principle applies to the second equation, resulting in 2Al + 3H2O ---> Al2O3 + 3H2. It also mentions that the classification of elements can affect the outcome of the product.
rash219
23
Ok the question is some what simple and difficult. I know there are certain rules like
a. A + B = AB (combination)
b. AB = A + B (decomposition)
c. AB + C = CB + A (substitution)
d. AB + CD = AD + CB (metathesis)
now the trouble i have is not in balancing the equation but figuring out what the out come of the reactants will be.
For example an unsolved and unbalanced equation.
___Ca(s) + ____H2O(l) ----> (?)
Why is the answer to the above question Ca(OH)2 + H2 and not CaO + H2...are there any particular rules i would have to know when figuring out the product of reactants.
Using the rules mentioned above would the following equation be right or wrong
___Al(s) + ____H2O(l) ----> (?)
result: 2Al + 3H2O ---> Al2O3 + 3H2
Also is there anything to do with classification of elements that change the out come of the product.
Thanks!
Both metal oxides and hydroxides are actually correct.
General rule is that, when react with cold water, metal hydroxide is produced whereas oxide is produced if steam is used.
Likes Govind_Balaji
In the first equation, calcium (which always has +2 charge in solution) will react with the anion formed by water, which is OH(-), not O(2-). Remember that once H2O loses a proton, it becomes a strong base that won't be willing to give up another proton. To balance the charges, one calcium ion accepts two hydroxide ions.
The same could be applied to the second equation. Give it a shot!
Related to How to determine the product of a Chemical Reaction.
1. What is a chemical reaction?
A chemical reaction is a process in which one or more substances (reactants) are transformed into new substances (products) through the breaking and forming of chemical bonds.
2. How do you determine the product of a chemical reaction?
To determine the product of a chemical reaction, you must first write a balanced chemical equation that shows the reactants and products of the reaction. Then, use stoichiometry to calculate the amount of each product that will be formed based on the amount of reactants used.
3. What factors affect the product of a chemical reaction?
The product of a chemical reaction can be affected by a variety of factors, including the amount and concentration of reactants, temperature, pressure, and the presence of a catalyst. The nature of the reactants and the type of reaction can also impact the products formed.
4. Can the product of a chemical reaction be predicted?
In most cases, the product of a chemical reaction can be predicted based on the reactants and the type of reaction. However, unexpected outcomes can occur due to factors such as impurities in the reactants, side reactions, or changes in reaction conditions.
5. How is the product of a chemical reaction identified?
The product of a chemical reaction can be identified through various methods, such as observing changes in color, temperature, or physical state of the substances involved. Chemical tests and spectroscopy can also be used to analyze the products formed and confirm their identities.
26K
9K
11K
