MHB How to Determine the Vertex of a Parabola?
  • Thread starter Thread starter Amer
    Parabola Vertex
To determine the vertex of a parabola given by the general equation $Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0$, the condition $B^2 = 4AC$ must hold. The example equation $4x^2 + 4xy + y^2 - 5x + 7y + 11 = 0$ is identified as a parabola, despite initial confusion labeling it as an ellipse. The vertex can be found by transforming the coordinates to align the parabola's axis with the coordinate axes, using new variables $(X,Y)$. The final vertex coordinates can be expressed in terms of the original coordinates, leading to specific values for $x$ and $y$.
Amer
The general equation of the parabola has the form
$Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0$ with $B^2 = 4AC$
what is the coordinate of the vertex of the parabola or in other word how to determine the vertex of a given parabola for example
$4x^2 + 4xy + y^2 - 5x + 7y + 11 =0 $
Thanks.
Mathematics news on Phys.org
Thanks.
$$Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0, \text{ with } A \neq 0, C=0$$
OR
$$Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0, \text{ with } A=0, C \neq 0$$
$4x^2 + 4xy + y^2 - 5x + 7y + 11 =0$ is an ellipse.
Thanks.
In general, the axis of the parabola will be at an angle to the coordinate axes. I think that the easiest way to find the vertex is probably to find some new coordinates $(X,Y)$ so that the axis of the parabola is parallel to one of the new coordinate axes.
If the equation is $4x^2 + 4xy + y^2 - 5x + 7y + 11 =0 $, then you can write it as $(2x+y)^2 = 5x - 7y - 11$. Take one of the new coordinates to be $Y = 2x+y$. The other coordinate $X$ must be perpendicular to $Y$, so take it to be $X = x-2y$. Next, solve the equations to get the old coordinates $(x,y)$ in terms of the new ones. That gives $x = \frac15(X+2Y)$, $y = \frac15(Y-2X)$. Substitute those values into the parabola equation, getting $Y^2 = (X+2Y) - \frac75(Y-2X) + 11$.
At this stage, the arithmetic gets messy, so I won't try to get the numbers correct. But in principle you can rearrange that last equation to get it into the form $(Y-\alpha)^2 = \beta(X-\gamma)$ for some coefficients $\alpha$, $\beta$, $\gamma$. You should be able to recognise that as a parabola with vertex at $(X,Y) = (\gamma,\alpha)$. Now all that remains is to express that in terms of the old coordinates $(x,y)$.
Strictly speaking, it is also required that
\begin{vmatrix}
A & B/2 & D/2\\
B/2 & C & E/2\\
D/2 & E/2 & F
\end{vmatrix}\ne0.
OR
If $A=0$ or $C=0$ while $B\ne0$, then it is not a parabola since $B^2\ne4AC$.
No, it's a parabola.
[GRAPH]7n1ibfij2l[/GRAPH]
The vertex of a parabola with equation $F(x,y)=0$ can be found as follows. First find the asymptotic direction $(\alpha,\beta)$ from the equation
A\alpha^2+B\alpha\beta+C\beta^2=0
(there are infinitely many nonzero solutions). Then the equation of the parabola axis is
-\beta\frac{\partial F}{\partial x}+\alpha\frac{\partial F}{\partial y}=0\qquad(*)
so the coordinates of the vertex can be found from (*) and $F(x,y)=0$.
In the case of
the asymptotic direction is $(1,-2)$, the axis is $20x+10y-3=0$ and the vertex is $x = \frac{1319}{1900}\approx 0.694$ and $y = -\frac{517}{475}\approx -1.088$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
