- #36
Rick16
- 81
- 25
Now you confuse me with the ##v-dv##. I mean, it seems to make sense. If the final velocity is ##v##, then the initial velocity should be ##v-dv##. But to me it also seemed to make sense to write ##m## for the initial mass and ##m-dm## for the final mass. If ##m-dm## is wrong, why is ##v-dv## correct?erobz said:Do you feel any better about the following where we let the final velocity of the rocket be ##v##?
$$ \begin{aligned} \sum F ~dt &=( p + dp )- p \\ \quad \\
& = ( M_r + M _f ) v + dm (v-u) - \left( M_r + M_f + dm \right)\left( v - dv \right) \\ \quad \\
&= \cancel{( M_r + M _f ) v} + \cancel{dm v} - dm u - \cancel{( M_r + M _f ) v} + ( M_r + M _f ) dv -\cancel{dm v} + \cancel{dm~dv}^0 \\ \quad \\
&= -dm u + ( M_r + M _f ) dv \end{aligned}$$
$$ \sum F = -\frac{dm}{dt}u + ( M_r + M _f )\frac{dv}{dt} $$
And with ## \frac{dm}{dt} = -\frac{dM_f}{dt}## we have:
$$ \sum F = \frac{dM_f}{dt} u +( M_r + M _f )\frac{dv}{dt} $$
$$ \text{"The Rocket Equation"}$$
You have ##v(t+dt)=v## and ##v(t)=v-dv##. If you switch to ##v(t)=v##, you get ##v(t+dt)=v+dv##. This looks perfectly okay.
But if I do the same with the mass, I run into a problem. If I use ##m(t+dt)=m## and ##m(t)=m+dm##, and I switch to ##m(t)=m##, then I get ##m(t+dt)=m-dm##. And this is not what I want to get.
