How to differentiate Doppler shift from star emission
In summary, to measure the Doppler shift of stars, you need to compare the frequency of spectral lines at the point of emission with the received frequency to determine the redshift. This involves identifying characteristic patterns of lines from different elements and their relative distances in the spectrum. The most abundant element, hydrogen, is often used as a reference for matching patterns and confirming the amount of shift. Additionally, the width of the lines can also provide information about the temperature and rotation of the star.
semc
368
I have seen people talking about measuring Doppler shift of stars to know how fast they are receding from us. But if I measured say a particular frequency f, how do I know whether this is shifted frequency or just the emission?
Astronomy news on Phys.org
Spectral lines are always at the same frequency at the point of emission. Compare it with the received frequency of these lines to get the redshift (expansion of the universe + Doppler effect + gravitational redshift).
You do not measure only single frequency but some broader part of the spectrum. You can then identify one or more characteristic lines based on their profiles and their relative distances in the spectrum. Once you got that, you know the redshift.
It's a pattern recognition problem. Different elements give off certain patterns of lines. So you're looking for that pattern, shifted from its normal position.
For instance sodium has a very characteristic close-together pair of lines, at 589.0 nm and 589.6 nm.
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/sodium.html
If you can find a pair with the right separation at some shifted wavelength, that tells you simultaneously that you're probably seeing sodium and also how much the shift is.
Hydrogen is by far the most abundant element, so I think that's the one that they typically match against first. And it wouldn't be based on just two lines, but a whole spectrum of lines. If you can find the spectra from multiple elements shifted by the same amount, that obviously confirms you've correctly identified the pattern and the amount of shift.
For example, the Hydrogen spectrum looks like this:
If you see bright lines in your spectrum in this pattern, but shifted to the left or right of the spectrum, you can tell that you are seeing Hydrogen lines Doppler shifted.
( As a side note: Since the surface of a star is made up of particles which are traveling at random directions with respect to you and at some average speed depending on the surface temp of the star, this produces a smearing out or "broadening" of the spectral lines, since the light from each of these moving particles adds its own component to the overall Doppler shift. The greater the average velocity of these particles, the broader the lines. Since this average velocity depends on star temp, the width of the lines can give us a way of measuring the star's temperature.)
Just looking at the overall spectrum is much easier.
The rotation of the star also contributes to the width of the lines, it can be used to estimate the rotation axis of stars.
Related to How to differentiate Doppler shift from star emission
1. What is Doppler shift and how does it relate to star emission?
Doppler shift is the change in frequency or wavelength of a wave due to the relative motion between the source of the wave and the observer. In the context of star emission, Doppler shift refers to the change in the wavelengths of light emitted by a star as it moves towards or away from the observer.
2. How can Doppler shift be differentiated from star emission?
Doppler shift can be differentiated from star emission by observing the specific patterns of spectral lines in the light emitted by a star. These spectral lines are unique to each element and can be used to determine if the shift in wavelength is due to the motion of the star or some other factor.
3. Is there a specific tool or equipment needed to differentiate Doppler shift from star emission?
Yes, specialized tools such as spectrometers are needed to measure the exact wavelengths of light emitted by a star and detect any shifts. These tools can also help identify the specific elements present in the star's atmosphere.
4. Can Doppler shift be used to measure the speed of a star?
Yes, Doppler shift can be used to measure the speed of a star relative to the observer. By analyzing the amount of shift in the spectral lines, astronomers can calculate the radial velocity of a star and determine if it is moving towards or away from us.
5. Are there any other factors that can contribute to Doppler shift besides the motion of a star?
Yes, in addition to the motion of the star, other factors such as the gravitational pull of nearby objects or the expansion of the universe can also cause Doppler shift. However, these shifts are typically much smaller and can be distinguished from the shifts caused by the motion of a star.
