How to divide an wav file into segments
  • Thread starter AK2
  • Tags
    File
In summary, to determine the length of each segment in a wav file, divide the total length by the desired number of segments. It is possible to divide a wav file into segments of different lengths by specifying the desired length for each segment. To ensure even divisions, use a mathematical function to round the segment length to the nearest integer. You can also specify the format of the segments by using a conversion tool. There are various software options available for dividing wav files, so choose one that is user-friendly and has the necessary features for your needs.
AK2
39
Does anybody know how to do this in matlab?
According to the MATLAB documentation, MATLAB imports mono sound as an m x 1 and stereo as m x 2, where m is the total number of samples in the file:
http://www.mathworks.com/help/techdoc/import_export/f5-132080.html#bsdufi0
Based on that information, you should be able to chop these up into shorter segments, and then re-save the resultant shorter segments using wavwrite:
http://www.mathworks.com/help/techdoc/ref/wavwrite.html
Related to How to divide an wav file into segments
1. How do I determine the length of each segment?
The length of each segment can be determined by dividing the total length of the wav file by the desired number of segments. For example, if you want to divide a 10-second wav file into 5 segments, each segment would be 2 seconds long.
2. Can I divide a wav file into segments of different lengths?
Yes, you can divide a wav file into segments of different lengths by specifying the desired length for each segment. This can be useful for creating segments with different durations for specific purposes.
3. How do I ensure that the segments are evenly divided?
To ensure that the segments are evenly divided, it is important to use a mathematical function such as floor or ceil to round the calculated segment length to the nearest integer. This will prevent any uneven divisions and ensure that all segments have equal lengths.
4. Can I specify the format of the segments?
Yes, you can specify the format of the segments by using a conversion tool. This will allow you to convert the segments into different audio formats such as MP3, AAC, or FLAC, depending on your needs.
5. What is the best software for dividing wav files into segments?
There are many software options available for dividing wav files into segments, such as Audacity, Adobe Audition, and WavePad. It is important to choose a software that is user-friendly and has the necessary features for your specific needs.
