How to draw the angles of the CKM matrix?
  • A
  • Thread starter Heidi
In summary, drawing the angles of the CKM (Cabibbo-Kobayashi-Maskawa) matrix involves understanding its representation in the complex plane. The CKM matrix describes the mixing of quark flavors in weak interactions and can be parameterized using three mixing angles and one CP-violating phase. To visualize the angles, one can employ the unitarity triangle, which is constructed from the relationship between the elements of the CKM matrix. The triangle's vertices correspond to different quark transitions, and the angles represent the phases of the CKM matrix elements. By plotting these relationships, one can effectively illustrate the geometrical representation of the CKM matrix angles, highlighting the importance of CP violation in particle physics.
Heidi
418
40
Hi Pfs,
please look at the CKM article on wikipedia
https://en.wikipedia.org/wiki/Cabibbo–Kobayashi–Maskawa_matrix
It begins with the case of two generation (with the Cabibbo angle)
We have two orthonorma basis related by a rotation
https://en.wikipedia.org/wiki/File:Cabibbo_angle.svg
I wonder if such a graphical representation exists with the CKM matrix (with three angles)
we would have two (three dimensional) basis and each of of vector eigenstate woul be associated to the 3 angles. Have you ever seen such a picture?
Such a body would have 8 dihedral angles and 5 constraints on these angles. That ignores the phase. What would such a thing even look like?
Likes vanhees71
I read this in the wikipedia article about the CKM matrix:
For the Standard Model case (n = 3), there are three mixing angles and one CP-violating complex phase.
Likes vanhees71
In the general case of a CKM matrix with n generation (n * n matrix)
the standard parameterization gives n(n-1)/2 angles but as it is a choice, it is not obvious
that the Euler angles appear clearly in a picture likr in tbe 2 * 2 case with its unique angle.
FAQ: How to draw the angles of the CKM matrix?
What is the CKM matrix and why are its angles important?
The Cabibbo-Kobayashi-Maskawa (CKM) matrix is a fundamental part of the Standard Model of particle physics. It describes the mixing between different generations of quarks during weak interactions. The angles of the CKM matrix, often referred to as the CKM angles, are crucial because they provide information about CP violation, which helps explain the matter-antimatter asymmetry in the universe.
How do you parameterize the CKM matrix to extract its angles?
The CKM matrix can be parameterized using three mixing angles (θ12, θ23, θ13) and a complex phase (δ). The standard parameterization is:\[ V_{CKM} = \begin{pmatrix}c_{12}c_{13} & s_{12}c_{13} & s_{13}e^{-i\delta} \\-s_{12}c_{23} - c_{12}s_{23}s_{13}e^{i\delta} & c_{12}c_{23} - s_{12}s_{23}s_{13}e^{i\delta} & s_{23}c_{13} \\s_{12}s_{23} - c_{12}c_{23}s_{13}e^{i\delta} & -c_{12}s_{23} - s_{12}c_{23}s_{13}e^{i\delta} & c_{23}c_{13}\end{pmatrix} \]where \( c_{ij} = \cos\theta_{ij} \) and \( s_{ij} = \sin\theta_{ij} \). The angles θ12, θ23, and θ13 can be extracted by comparing this parameterization with the experimentally determined CKM matrix elements.
What are the experimentally determined values of the CKM angles?
The experimentally determined values of the CKM angles are approximately:- θ12 ≈ 13.1°- θ23 ≈ 2.4°- θ13 ≈ 0.2°These angles are derived from various measurements of quark decays and other processes involving weak interactions. The complex phase δ is also determined experimentally to be around 68°.
How can you visualize the CKM angles in a unitary triangle?
The CKM angles can be visualized using the Unitarity Triangle, which is a graphical representation of the unitarity condition of the CKM matrix. One of the most common triangles is formed by the elements VudVub* + VcdVcb* + VtdVtb* = 0. The angles of this triangle, known as α, β, and γ, are related to the CKM
