How to -- electric boiler design
In summary, the conversation discusses the use of the ASME Boiler and Pressure Vessel code for the thermal design of small electric steam boilers. It is mentioned that the code covers the design and manufacture of components, but not the thermodynamics of the boiler design. The speaker confirms that it is possible to design a boiler for a 10kW electric heater for a steam engine using the ASME code. They also mention that there are many different designs available and ask if there is any specific information the asker is looking for.
y2j
50
Hi all
Are there is an idea to design (thermal design )the size of an small electric steam boiler if the heat input is about (10 Kw)
can one use the ASME for (boiler and pressure vessel code ),is also contain a thermal design of boilers?
I believe the ASME B & PV code covers just the design and manufacture of the components (e.g., material selection, strength, testing, etc.)
The thermodynamics of the boiler design is not covered.
If I read you right, you are asking if anyone knows how to design a boiler for a steam engine which has 10kW electric heater of some kind.
The short answer is "yes" - designing steam engines is quite a mature field in engineering. There are an infinite number of possible designs.
Is there anything you specifically wanted to know?
(two similar threads merged)
Related to How to -- electric boiler design
1. What are the main components of an electric boiler?
The main components of an electric boiler include a heating element, a control system, a water tank, and a pump. The heating element is responsible for heating the water, while the control system regulates the temperature and ensures safety. The water tank stores the heated water, and the pump circulates it throughout the system.
2. How does an electric boiler work?
An electric boiler works by using an electric heating element to heat the water inside the tank. The control system monitors the temperature and turns the heating element on or off as needed. As the water heats up, it rises to the top of the tank and is then circulated throughout the system by the pump.
3. What factors should be considered when designing an electric boiler?
When designing an electric boiler, factors such as the size and type of heating element, the capacity of the water tank, and the efficiency of the control system should be considered. The desired temperature and flow rate of the water should also be taken into account.
4. How can the efficiency of an electric boiler be improved?
To improve the efficiency of an electric boiler, insulation can be added to the tank to reduce heat loss. The control system can also be optimized to ensure the heating element is only activated when needed. Proper maintenance, such as regular cleaning and descaling, can also help improve efficiency.
5. Are there any safety precautions to consider when designing an electric boiler?
Yes, there are several safety precautions to consider when designing an electric boiler. The heating element should be properly insulated to prevent electrical shocks. The control system should have safety features, such as overheat protection and automatic shut-off, to prevent accidents. Regular maintenance and inspections should also be conducted to ensure the boiler is functioning safely.
  • Mechanical Engineering
