How to estimate the power of laser beam
In summary, the conversation discusses the relationship between Rabi frequency and the power of a laser beam in a 2-level system. The Rabi frequency is a constant for a constant input laser power, but the calculation for power takes into account the frequency of the laser and the electric dipole moment. An estimate for the power can be obtained by calculating the average intensity and multiplying it by the area of the laser beam profile. However, this is just an estimate and may not be accurate in all cases.
KFC
488
I posted a question about Rabi frequency here https://www.physicsforums.com/threads/what-is-rabi-frequency.331082/ some times ago. The replies there answer some of my questions but I am still looking for detail explanation on the relation between Rabi frequency and the power of the beam. I read some more materials online. There I understand that if I have a 2 level system where the Rabi frequency is a constant if the input laser is of constant power. I am thinking if we shine that laser beam (as pulse with duration ##\Delta t##) to the system. How can we figure out the power of the laser if we know Rabi frequency ?
I am thinking ##\hbar \Omega## is of the unit of energy so is the power of laser should be ##\hbar\Omega/\Delta t## if ##\Delta t## is the duration of the pulse? Someone said this is not correct because if depends on how much the frequency of laser off from the resonance frequency also. But how do we add that and get the correct expression for power?
I will give an estimate way for your problem. Assuming monochromatic or quasi-monochromatic laser beam (valid for CW laser) of frequency ##\omega##, the Rabi frequency reads ##\Omega = \sqrt{(\mu E_0)^2 + (\omega-\omega_0)^2}##, where ##\omega_0## the frequency between the two levels in question and ##\mu## the electric dipole moment between those two levels. If you know everything you can calculate ##E_0##, then the average intensity (for plane wave) ##I = \frac{1}{2}\epsilon_0 c E_0^2##, and finally the average power. To estimate the last one you need to multiply the average intensity with some area, let's say area bounded by the FWHM of the laser beam profile. Again I would like to stress that this is an estimate. In reality people would probably use pulsed instead of CW laser, and the non-uniform beam profile might contribute to further discrepancy.
Related to How to estimate the power of laser beam
1. How is the power of a laser beam measured?
The power of a laser beam is typically measured in watts (W) or milliwatts (mW). This is the amount of energy that the laser beam delivers per unit of time.
2. What factors affect the power of a laser beam?
The power of a laser beam can be affected by several factors, including the type of laser, the quality of the optics used, the beam size and shape, and any environmental factors such as temperature or humidity.
3. How can I estimate the power of a laser beam without specialized equipment?
If you do not have access to specialized equipment, you can estimate the power of a laser beam by measuring the beam diameter and using a laser power density calculator. This will give you an approximation of the power based on the beam's intensity.
4. Can the power of a laser beam be adjusted or controlled?
Yes, many lasers have the ability to adjust or control their power output. This can be done through the use of different optics, adjusting the current or voltage to the laser, or using an external power control device.
5. How does the power of a laser beam affect its potential applications?
The power of a laser beam can greatly impact its potential applications. A higher power laser beam will typically have greater cutting, welding, or engraving capabilities, while a lower power laser may be more suitable for precision measurements or medical procedures.
  • Atomic and Condensed Matter
  • Quantum Physics
