How to Evaluate √1061520150601 Without a Calculator?
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, there are multiple ways to evaluate the square root of 1061520150601 without a calculator, including using the long division method, the Babylonian method, and other more advanced methods. Knowing how to do this can improve mental math skills, allow for error-checking of calculator results, and solve mathematical problems without relying on technology. Some shortcuts and tricks can also be used to simplify the calculation or get a rough approximation.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Without the help of calculator, evaluate $\sqrt[6]{1061520150601}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution:):
1. greg1313
2. Ackbach
3. lfdahl
4. RLBrown
5. kaliprasad
Solution from Ackbach:
The original number is $1061520150601\sim 10^{12}$. Hence, we expect the answer to be roughly $100$, and it must be greater than $100$. Now, we find that $110^2=12100$, and we can see immediately that the second digit in from the far left is only going to get greater and greater as we get up to the full sixth power. So the result must be less than $110$. The original number is odd, forcing the answer to be odd. The original number is not divisible by $5$, which rules out $105$. We still have $101, 103, 107,$ or $109$ as possible answers. The method of "casting out nines", or arithmetic modulo nine, does not rule out any of these possibilities, unfortunately. Note that $101^2=(100+1)(100+1)=10000+200+1=10201$. Then $101^4=10201^2=104060401$. From here it is not difficult to determine that $10201\cdot 104060401=1061520150601$, so the answer is $101$.
Alternate solution from kaliprasad:
$1061520150601$
= $1* 10^12 + 6 * 10^10 + 15 * 10^8 + 20 * 10^6 + 15 * 10^4 + 6 * 10^2 + 1$
= $(100 + 1)^6$ using binomial expansion
= $101^6$
so 6 th root of $1061520150601= 101$
FAQ: How to Evaluate √1061520150601 Without a Calculator?
What is the square root of 1061520150601?
The square root of 1061520150601 is approximately 32599.999959234.
How can I evaluate the square root of 1061520150601 without a calculator?
One way to evaluate the square root of 1061520150601 without a calculator is by using the long division method. This involves finding the largest perfect square that is a factor of 1061520150601 and then using long division to calculate the square root. Alternatively, you can use the Babylonian method, which is an iterative algorithm that involves repeatedly refining an initial guess until it is close enough to the actual square root.
Why is it important to know how to evaluate the square root of 1061520150601 without a calculator?
Knowing how to evaluate the square root of 1061520150601 without a calculator can be helpful in situations where a calculator is not available or when you want to improve your mental math skills. It also allows you to check the accuracy of calculator results or to solve mathematical problems without relying on technology.
Are there any shortcuts or tricks for evaluating the square root of 1061520150601 without a calculator?
Yes, there are some shortcuts and tricks that can make it easier to evaluate the square root of 1061520150601 without a calculator. For example, you can use the properties of perfect squares to simplify the calculation or use estimation techniques to get a rough approximation of the square root.
Can I use a different method to evaluate the square root of 1061520150601 without a calculator?
Yes, there are other methods that can be used to evaluate the square root of 1061520150601 without a calculator, such as the continued fraction method or the Heron's method. However, these methods may require more advanced mathematical knowledge and may not be as straightforward as the long division or Babylonian method.
