How to Evaluate the Infinite Sum for 0 < x < 1?
In summary, to find the sum for 0 < x < 1, we need to differentiate the logarithm of a product that involves a fraction with a denominator that can be simplified to 1-x. This can be simplified further to 1/(1-x), and the resulting sum is equal to -2x-1/(1+x+x^2).
lfdahl
MHB
749
For 0 < x< 1, find the sum:
\[\frac{2x-1}{1-x+x^2}+\frac{4x^3-2x}{1-x^2+x^4}+\frac{8x^7-4x^3}{1-x^4+x^8}+ ...\]
Mathematics news on Phys.org
[sp]\[\frac{2x-1}{1-x+x^2}+\frac{4x^3-2x}{1-x^2+x^4}+\frac{8x^7-4x^3}{1-x^4+x^8}+ \ldots\]
\[= \frac{\frac d{dx}(1-x+x^2)}{1-x+x^2} + \frac{\frac d{dx}(1-x^2+x^4)}{1-x^2+x^4}+\frac{\frac d{dx}(1-x^4+x^8)}{1-x^4+x^8}+ \ldots\]
\[= \frac d{dx}\bigl(\ln(1-x+x^2)\bigr) + \frac d{dx}\bigl(\ln(1-x^2+x^4)\bigr) + \frac d{dx}\bigl(\ln(1-x^4+x^8)\bigr) + \ldots\]
\[= \frac d{dx}\left(\ln\left(\frac{1+x^3}{1+x}\right) + \ln\left(\frac{1+x^6}{1+x^3}\right) + \ln\left(\frac{1+x^{12}}{1+x^6}\right) + \ldots\right)\]
\[= \frac d{dx}\left(\ln\left(\frac{1+x^3}{1+x}\frac{1+x^6}{1+x^3}\frac{1+x^{12}}{1+x^6} \cdots\right)\right)\]
\[= \lim_{n\to\infty} \frac d{dx}\left(\ln\left(\frac{1+x^{3\cdot2^n}}{1+x}\right)\right)\]
\[ = \frac d{dx}\left(\ln\left(\frac{1}{1+x}\right)\right)\]
\[= \frac d{dx}\bigl(-\ln(1+x)\bigr) = - \frac1{1+x}\]
Some of those steps may need heavy machinery to justify them (differentiating a series term by term, interchanging limits, ...). But that should all work satisfactorily for $0<x<1$.
[/sp]
[/sp]
Hi, Opalg
I´m afraid, there is an error in your calculus :(
There is not a telescoping product, because:
\[1-x+x^2 = \frac{1+x^3}{1+x} \\\\ 1-x^2+x^4 = \frac{1+x^6}{1+x^2} \\\\ 1-x^4+x^8 = \frac{1+x^{12}}{1+x^4} \\\\ 1-x^8+x^{16} = \frac{1+x^{24}}{1+x^8} \;\;...\]
Opalg said:
[sp]Some of those steps may need heavy machinery to justify them (differentiating a series term by term, interchanging limits, ...). But that should all work satisfactorily for $0<x<1$.
[/sp]
IMHO the part that needs most justification is going from the fourth to the fifth line, where it’s assumed that
$$\sum_{n=1}^\infty\ln x_n\ =\ \ln\left(\prod_{n=1}^\infty x_n\right)$$
(which in turn assumes that the sum of the left and the product on the right converge).
lfdahl said:
Hi, Opalg
[sp]Oops, you're right, the product does not telescope at all! It should be
\[\frac d{dx}\left(\ln\left(\frac{1+x^3}{1+x}\frac{1+x^6}{1+x^2}\frac{1+x^{12}}{1+x^4}\frac{1+x^{24}}{1+x^8} \cdots\right)\right)\]
The denominators then form the product
\[(1+x)(1+x^2)(1+x^4)(1+x^8)\cdots = 1+x + x^2 + x^3 + x^4 + x^5 + x^6 + \ldots = \frac1{1-x}.\]
The numerators are the same, with $x^3$ instead of $x$, so their product is $\dfrac1{1-x^3}.$ Therefore we need to find
\[\frac d{dx}\left(\ln\left(\frac{1-x}{1-x^3}\right)\right) = \frac d{dx}\left(\ln\left(\frac1{1+x+x^2}\right)\right) = \frac d{dx}\bigl(-\ln(1+x+x^2)\bigr) = -\frac{2x+1}{1+x+x^2}.\]
I hope that works better than my first attempt.
[/sp]
[/sp]
Thankyou for participating in this challenge, Opalg! Yes sure, your 2nd attempt works perfect!
Hi, Olinguito
Thankyou for your sharp observation in Opalg´s solution concerning convergence.
Do you perhaps have any idea of how to prove convergence for both sides of the equation? Or is it sufficient to show, that we´re dealing with two geometric series, and that $0<x<1$?
FAQ: How to Evaluate the Infinite Sum for 0 < x < 1?
What is an infinite sum?
An infinite sum is a mathematical concept that involves adding an infinite number of terms together. It is often denoted by the symbol ∑ and can be written as ∑n=1 an, where n represents the index or position of the term and an represents the value of each term.
How do you evaluate an infinite sum?
To evaluate an infinite sum, you can use various methods such as the geometric series test, telescoping series, or partial sums. The method used depends on the type of series and its convergence or divergence.
What is the formula for the given infinite sum?
The given infinite sum can be written as ∑n=1 (2x-1)/(1-x+x^2)+(4x^3-2x)/(1-x^2+x^4)+(8x^7-4x^3)/(1-x^4+x^8). This can also be written in a more compact form as ∑n=1 (2xn-1)/(1-xn+x2n).
How do you simplify the given infinite sum?
To simplify the given infinite sum, you can use partial fractions and algebraic manipulation to rewrite the fraction terms into a form that can be summed using known series. In this case, you can use the formula for the sum of a geometric series to simplify each term.
What are the possible values of x for which the given infinite sum converges?
The given infinite sum will converge for values of x that make the individual terms converge. This can be determined by using convergence tests such as the ratio test or root test. In this case, the sum will converge when |x| < 1.
