How to Evaluate This Interesting Expression?
  • MHB
  • Thread starter anemone
  • Tags
    Expression
In summary, an expression is a mathematical statement with numbers, variables, and operations that can be evaluated to produce a single numerical value. To evaluate an expression, follow the order of operations (PEMDAS). An equation is a statement showing the equality between two expressions, typically with an equal sign. You cannot evaluate an expression without knowing the values of the variables. There are special rules for evaluating expressions, such as flipping fractions when dividing and changing signs when multiplying or dividing by negative numbers. It's important to carefully follow the order of operations to get the correct answer.
anemone
MHB
POTW Director
3,883
115
Evaluate $1\cdot 2^2 + 1\cdot 2\cdot 3^2 + 1\cdot 2\cdot 3\cdot 4^2 +\cdots+ 1\cdot 2\cdot 3\cdots 2015^2− (1\cdot 2\cdot 3\cdots 2016)$.
Mathematics news on Phys.org
My solution:
First, let's prove by induction the following hypothesis $P_n$:
\(\displaystyle \sum_{k=a}^n(k\cdot k!)=(n+1)!-a!\)
1.) The base case $P_a$:
\(\displaystyle \sum_{k=a}^n(k\cdot k!)=a\cdot a!=a!((a+1)-1)=(a+1)!-a!\)
The base case is true.
2.) The induction step:
Add through by \(\displaystyle (n+1)(n+1)!\):
\(\displaystyle \sum_{k=a}^n(k\cdot k!)+(n+1)(n+1)!=(n+1)!-a!+(n+1)(n+1)!\)
\(\displaystyle \sum_{k=a}^{n+1}(k\cdot k!)=(n+1)!((n+1)+1)-a!\)
\(\displaystyle \sum_{k=a}^{n+1}(k\cdot k!)=((n+1)+1)!-a!\)
We have derived $P_{n+1}$ from $P_n$ thereby completing the proof by induction.
And so we may now state:
\(\displaystyle S=\sum_{k=2}^{2015}(k\cdot k!)-2016!=(2015+1)!-2!-2016!=-2\)
MarkFL said:
My solution:
Very well done MarkFL!(Cool)
1st let us evaluate the sum
1st we see that $n^{th}$ term = $n * n! = (n+1-1) * n!= (n+1)! - n!$
when we sum the above from 2 to 2015 we get as a telescopic sum 2016!- 2 !
subtracting the last value that is 2016! we are left with -2! or - 2
Thanks for participating, kaliprasad!
For your information, that is exactly how I approached this particular problem as well! (Cool)
FAQ: How to Evaluate This Interesting Expression?
What is the definition of an expression?
An expression is a mathematical statement that contains numbers, variables, and operations. It can be evaluated to produce a single numerical value.
How do you evaluate an expression?
To evaluate an expression, you must follow the order of operations, also known as PEMDAS (Parentheses, Exponents, Multiplication and Division, Addition and Subtraction). Start by simplifying any operations within parentheses, then move on to exponents, multiplication and division (working from left to right), and finally addition and subtraction (also working from left to right).
What is the difference between an expression and an equation?
An expression is a mathematical statement that can be evaluated to produce a single value, while an equation is a statement that shows the equality between two expressions. Equations typically have an equal sign (=) between the two expressions, whereas expressions do not.
Can you evaluate an expression without knowing the values of the variables?
No, you cannot evaluate an expression without knowing the values of the variables. Variables represent unknown values, and without knowing their values, you cannot perform the necessary operations to simplify the expression.
Are there any special rules for evaluating expressions?
Yes, there are a few special rules to keep in mind when evaluating expressions. For example, when multiplying or dividing by a negative number, the signs of the numbers involved will change. Also, when dividing by a fraction, you must flip the fraction and multiply instead. It's always important to carefully follow the order of operations to ensure the correct answer is obtained.
