MHB How to exclude combinations for defined sequences?
The discussion revolves around calculating the probability of a factory having to close its production line due to product failures over specified time periods, given a failure rate of 0.05. The user successfully computed probabilities for one year and 13 months but is struggling with the calculations for 15 months and 10 years. They seek a general rule to exclude combinations that would lead to shutdowns, particularly for longer periods and multiple failures. Suggestions include using Markov chains or renewal models for the 10-year calculation, as raw combinatorial methods may be overly complex. The overall focus is on developing a systematic approach to handle these probability calculations effectively.
Josefk
Please can anyone help with the below problem? It’s an interesting problem but please bear with me as i don't have much math background.
A factory’s product is sampled once per month every month by its quality inspection team. The factory is allowed up to 2 product failures per ROLLING 12 month period (i.e. Mar-Feb, April-Mar etc) but if it fails 3 times it must close its production line. The probability of failing each sample is 0.05. Work out the probability that (given that the factory hasnt had any failures in the last 12 months) the factory will have to close its production line on AT LEAST one occasion:
a) in the next 12 months
b) in the next 13 months
c) in the next 15 months
d) in the next 10 years
My answers so far:
I really need help with part c) and particularly part d).
a) using standard binomial probability (12!/3!9! x 0.05^3 x 0.95^9)+(12!/4!8! x 0.05^4 x 0.95^8)+ etc ... +(12!/12!0! x 0.05^12 x 0.95^0) = 0.0196.
b) Using the number of combinations taken from part a), i deducted from the first term those combinations that do not have 3 failures within 12 months of each other (let’s call this the ‘no shutdown’ combinations). To work this out, i reasoned the only possible combinations are those with a single failure at both ends of the range. So i did 2!/2!0! X 11!/11!0! = 11. (this seems correct after i physically sketched the combinations out!). There is no need to repeat this for the second term (for 4 failures) as there is no possible combination here that won't have 3 failures within 12 months of each other. The overall probability i calculated to be 0.0237.
c). I’m struggling to work out the number of ‘no shutdown’ combinations for 3 failures within 15 months and also for 4 failures (as this term now becomes significant). I need to be able to develop a rule for working this out. Similar to part b) i have tried to work out the combinations of failures occurring within the end 4 months of the range (i.e. months 1,2,14,15) such to avoid 3 occurring within 12 months. To do this i did (4!/3!1! X 11!/11!0!) + (4!/2!2! X 11!/10!1!) + (4!/1!3! X 11!/10!2!) = 92. However, when i sketched the combinations out by hand there are only 76, so i seem to be double counting 16 combinations using the above approach.
In order to work out part d) i will need a general rule to exclude the ‘no shutdown’ months for any number of months (m) being considered and any number of failures up to m-3.
CAN ANYONE HELP PLEASE?
Mathematics news on Phys.org
Josefk said:
Please can anyone help with the below problem? It’s an interesting problem but please bear with me as i don't have much math background...
d) in the next 10 years...
This could be an issue. Structurally, this feels like a modified runs problem, which means it is fairly easily addressable with markov chains or a renewal model. Doing the 10 year problem with raw combinatorics may be technically possible with inclusion-exclusion, though it seems laborious and unpleasant.
So, what do you know and where is this problem coming from? If you really don't have much of a math background, I'd suggest working out all the mechanics on a, b, and c and ignoring d.edit: I may be able to frame the renewal argument as just a big linear recurrence involving mutually exclusive events -- if you're ok with such things then that should work.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
