Hilly117
- 1
Factorise:
f(x)=x^3-10x^2+17x+28
SteamKing said:There is a quite obvious factor to consider in such cases: +1 or -1.
A cubic polynomial is a polynomial function of degree 3. It is characterized by having the highest power of the variable raised to 3, and usually takes the form ax^3 + bx^2 + cx + d, where a, b, c, and d are coefficients.
Factoring a cubic polynomial allows us to break down a complex expression into simpler forms, making it easier to solve and analyze. It also helps us identify the roots or solutions of the polynomial, which are the values of x that make the polynomial equal to 0.
There are several methods for factoring a cubic polynomial, including grouping, factoring by grouping, and using the cubic formula. The most commonly used method is the grouping method, where the polynomial is split into two parts and factored separately.
A cubic polynomial is not factorable if it has complex or irrational roots. This can be determined by using the rational root theorem or by using the cubic formula to solve for the roots. If the roots are not rational numbers, then the polynomial is not factorable.
Cubic polynomials are commonly used in physics, engineering, and economics to model real-life situations. For example, they can be used to analyze the trajectory of a projectile, determine the optimal production level in a manufacturing process, or calculate the optimal pricing for a product. Factoring them can help us understand the behavior of these systems and make informed decisions.
