How to Factorize x^2-y^2-x+y for Solving Polynomial Equations
In summary: To get this, we use the distributive law. The $x-y$ is distributed to both terms in $(x+y)-1$. This gives us:$(x-y)(x+y-1)$which is the correct factored form.
mathlearn
331
Factorise \(\displaystyle x^2-y^2-x+y\). Any Ideas on how to begin (Mmm)
Mathematics news on Phys.org
If you observe that:
\(\displaystyle x^2-y^2=(x+y)(x-y)\)
and
\(\displaystyle -x+y=-(x-y)\)
then can you proceed to factor?
and
Thanks (Yes)
so now to factor (x+y)(x-y)-(x-y)
Can this be factorised any further ? Agree ?(Thinking)
Many Thanks (Happy)
mathlearn said:
Thanks (Yes)
Many Thanks (Happy)
When you have an expression of 4 or more terms, a good strategy is the group some of them together. This problem has 4 terms. One try would have been to group 3 together and leave one by itself. Another approach (as hinted by MarkFL) is to group 2 together and 2 together. You have done this and arrived at \(\displaystyle (x+y)(x-y)-(x-y)\). Now ask yourself how you would factor \(\displaystyle ab-b\).
Hope this is the answer $ x^2-y^2-x+y=(x^2-y^2)-(x-y)=(x-y)(x+y)-(x-y)=(x-y)(x+y-1)$
But I am not exactly clear on how did $(x-y)(x+y)-(x-y)$ become $(x-y)(x+y-1)$, Apologies because I am not that much good at factoring. (Crying)
I know that this is the case, but can someone explain it a little , replacing the ab-b with the relevant terms.
If possible can a resource on factorization be posted.
Many Thanks :rolleyes:
Do you know what "factorization" means? Did you recognize that ab- b= (a- b)b?
Compare ab- b to (x+ y)(x- y)- (x- y). What do you think "a" and "b" are in terms of x and y?
there is a typo error above ab-b =(a-1)b
Oops! Thanks!
$x^2-y^2-x+y=(x^2-y^2)-(x-y)=(x-y)(x+y)-(x-y)=(x-y)(x+y-1)$
$(x-y)(x+y)-(x-y)=(x-y)(x+y-1)$
As there are two $(x-y)$ , take it once and now a '-1' is isolated,
$(x-y)(x+y)-(x-y) = (x-y)(x+y)-1 = (x-y)(x+y-1)$
Correct?
This is correct.
This is not correct. This should be:
$(x-y)(x+y)-(x-y) = (x-y)((x+y)-1) = (x-y)(x+y-1)$
MarkFL said:
This is correct.
Can you explain a little bit on what happens there in words. (Smile)
Look at the difference between what you posted and what I posted. You simply did not use correct bracketing symbols...you left that $-1$ dangling out there by itself. You essentially stated that:
\(\displaystyle ab-a=ab-1\)
when what we want is:
\(\displaystyle ab-a=a(b-1)\)
FAQ: How to Factorize x^2-y^2-x+y for Solving Polynomial Equations
1. What is factorization and why is it important?
Factorization is the process of breaking down a number or expression into its smaller, simpler components. It is important because it allows us to solve equations and find common factors, which can help us simplify complex expressions and make calculations easier.
2. What are the main methods of factorization?
The main methods of factorization include the trial and error method, the method of grouping, and the use of special formulas such as the difference of squares and perfect square trinomials. There are also more advanced methods such as the quadratic formula and prime factorization.
3. Can you provide an example of factorization?
Sure, let's factor the expression 3x^2 + 12x. We can first find the common factor, which in this case is 3x. This leaves us with 3x(x+4). We can then further factor the expression by finding the factors of 4, which are 1, 2, and 4. After some trial and error, we see that 3x(x+4) can be factored into 3x(x+2)(x+2).
4. How does factorization relate to prime numbers?
Prime numbers are numbers that can only be divided by 1 and itself. Factorization is the process of breaking down a number into its smaller factors, and prime factorization is the process of breaking down a number into its prime factors. This means that prime numbers are the building blocks of factorization, as they cannot be broken down any further.
5. What are some real-world applications of factorization?
Factorization has many real-world applications, such as in cryptography where it is used to create and break codes, in chemistry to balance chemical equations, and in economics to find the most efficient way to distribute goods. It is also used in computer algorithms and data compression to make calculations and storage more efficient.
