How to find absolute min/max of f(x)=x^3+3x^2-24x+1 on[-1,4]
  • Thread starter Thread starter brandon cheatham
    Absolute Derivative
To find the absolute minimum and maximum of the function f(x)=x^3+3x^2-24x+1 on the interval [-1, 4], critical points must be determined by taking the derivative and setting it to zero. The derivative yields critical numbers, with x=2 being the only valid point within the interval. Evaluating the function at the critical point and the endpoints, f(-1) results in 23 and f(2) gives -27. It is essential to include the function values at both endpoints to accurately identify the absolute min and max. The absolute maximum is 23 at x=-1, and the absolute minimum is -27 at x=2.
brandon cheatham
I need to find the absolute min and absolute max.
I first took the derivative, reduced, and set it to equal 0 to find crit numbers.
x^2+2x-8=0
Factored.
(x+4)(x-2) = 0
so x=-4 or x=2 but since -4 is not on the interval i threw it out and kept 2 as my only crit #
I plugged in my critical number along with my LB and RB numbers to find:
Aboslute Max. to be (-1,23)
Absolute Min. to be (2-27)
Am I doing this correctly? This was a take home quiz given in my calculus class and I want to make sure it is correct before I turn it in. Thanks! 234
[/B]
Hi brandon:
You need to include the end points of the range, -1 and 4, whether or not they derivative is zero for those values. Then you need to evaluate f(x) at the derivative's zeros and at the boundaries.
Regards,
Buzz
x^2+2x-8=0
Factored.
(x+4)(x-2) = 0
Am I doing this correctly? This was a take home quiz given in my calculus class and I want to make sure it is correct before I turn it in. Thanks! 234[/B]
Please read the posting guidelines. Specifically, you are requested not to use large or bold face fonts, nor to post equations in the subject line of the post.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 30 ·
  • · Replies 36 ·
  • · Replies 24 ·
