How to find all solutions of ## 3x-7y\equiv 11\pmod {13} ##?
  • Thread starter Thread starter Math100
The discussion focuses on solving the linear congruence 3x - 7y ≡ 11 (mod 13). The key steps involve rewriting the equation to isolate x, leading to x ≡ 11y + 8 (mod 13). Since y can take any value from 0 to 12, there are 13 distinct solutions for (x, y). The solutions can be expressed as (x, y) = (11y + 8, y) for y in the specified range. The conclusion emphasizes that the congruence represents a line with 13 points in the finite field of integers modulo 13.
Math100
Find all solutions of the linear congruence ## 3x-7y\equiv 11\pmod {13} ##.
None.
Consider the linear congruence ## 3x-7y\equiv 11\pmod {13} ##.
Then ## 3x\equiv 11+7y\pmod {13} ##.
Note that ## gcd(3, 13)=1 ## and ## 1\mid 11 ##.
This means ## y\in\ {0, 1,..., 12} ##.
And now I'm stuck. The book's answer shows ## x\equiv 11+t\pmod {13}, y\equiv 5+6t\pmod {13} ##. But based on my previous work shown above, how should I get to the correct answer for this problem?
I'm not sure why they would write the answer in that manner. I'd start with (you can fill in some blanks)
##3x - 7y \equiv 11##
##3x \equiv 11 + 7y##
Multiply both sides by ##3^{-1}## to get x. Then you have
##x \equiv 8 + 11y##
Personally I'd leave it there, but if you like set ##x \equiv t##. Then solve ## t \equiv 8 + 11y## for y and you get ##y \equiv 6 t+ 2##.
I'll leave it to you to figure out how to get ##x = 11 + t## and ##y \equiv 5 + 6t## from there.
If you need more help, show us what you've got and we'll take it from there.
-Dan
Likes fresh_42
Let's forget about the theorems for a moment.
We have ##3x-7y\equiv 11\pmod{13}## and all numbers here are coprime, so they all have inverses modulo ##13.## However, we have two variables but only one equation. It is now the same calculation which you use to solve linear equation systems. Only that we do not have rational numbers, but ##\{0,1,2,\ldots,12\}## instead.
Let's solve ##3a\equiv 1\pmod{13}.## We have ##3\cdot (-4)\equiv -12 \equiv 1 \pmod{13}## so ##a=3^{-1}\equiv -4\equiv 9\pmod{13}.## From that we get
\begin{align*}
3x-7y\equiv 11\pmod{13} &\Longrightarrow 9\cdot 3x-9\cdot 7y=99\pmod{13} \\
&\Longrightarrow 27x-63y\equiv 99\pmod{13}\\
&\Longrightarrow x-11y\equiv 8 \pmod{13} \\&\Longrightarrow x=11y+8
\end{align*}
##y## is arbitrary, a free parameter. So you could either choose any ##y## and calculate ##x## from it or the other way around.
Likes topsquark
\begin{align*}
\end{align*}
Since ## y\in {0, 1,..., 12} ##, it follows that ## x=11(0)+8=0+8=8 ##. So ## x=8, y=0 ##. Then what should be the answer?
The answer is a set that has as many elements as there are solutions. Since ##y## can freely be chosen, there will be thirteen answers, for every value of ##y## one. You have noted ##(x,y)=(8,0).## The solution is either ##\{(x,y)=(11y+8,y)\pmod{13}\,|\,0\leq y \leq 12\}## or you list all thirteen: ##\{(8,0),(6,1),(4,2),\ldots\}.##
Likes topsquark and Math100
I do not think listing all thirteen pairs of sets is a good idea, but I do prefer the first solution you've provided.
The point that you should get here is, that the remainders of primes, here ##13,## form a field. Fields are structures where we can add, subtract, multiply and divide. We normally only consider the rational numbers, or the reals, maybe even the complex numbers. But ##\{0,1,2,\ldots,12\}## is a field, too. It has only thirteen elements, but it provides all calculation rules. Therefore ##3x-7y=11\pmod{13}## is the equation of a straight in a plane. The plane has only ##13^2=169## points, but who cares? The straight has ##13## points.
