How to find angles of a triangle
In summary, the problem involves finding angles B and C in a triangle ABC, given that angle A is equal to \alpha and side a is equal to the average of b and c. The problem has solutions for any value of \alpha, and you can use the cosine and sine theorems to obtain equations with two unknowns, but it may be difficult to solve. Additionally, the bisector of angle A divides side a into two segments, b/2 and c/2, which can be used to find the angles at B and C using trigonometric functions.
Andrei1
36
We know that in triangle ABC angle A equals \(\displaystyle \alpha\) and side \(\displaystyle a=\frac{b+c}{2}.\) How to find angles B and C knowing that \(\displaystyle B\geqslant C\)? For which values of \(\displaystyle \alpha\) the problem has solutions?
ps. a, b, c are only notations.
answer. \(\displaystyle \frac{\pi-\alpha}{2}\pm\arccos(2\sin\frac{\alpha}{2})\)
Mathematics news on Phys.org
Re: how to find angles of a triangle
It seems you have given $\alpha$ in terms of $\alpha$.
Here is what I do. I express a through b, c and \(\displaystyle \alpha\) by cosine theorem. So I have an equation with only b and c as unknown. I obtain \(\displaystyle \frac{b}{c}\) by sine theorem and I substitute this ratio in the first equation. I also know that \(\displaystyle \alpha=\pi-B-C.\) So I have two equations with two unknowns. But it is hard to solve.
I also noticed that the bisector of angle A divide side a in two segments: b/2 and c/2.
I think you are nearly there. Look at this picture, in which $AD$ is the angle bisector at $A$, and $BN$ is perpendicular to $AD$:
The angle at $B$ is obviously $\angle ABN + \angle NBD$. Equally obviously, $\angle ABN = \frac{\pi}2 - \frac\alpha2$, so we just need to show that $\cos(\angle NBD) = 2\sin\bigl(\frac\alpha2\bigr)$. But $\cos(\angle NBD) = \frac{BN}{BD}$, and you have already shown that $BD = c/2$, so you just need to observe that $BN = c\sin\bigl(\frac\alpha2\bigr)$, which is evident from the triangle $ABN$.
You can get the result for the angle at $C$ in a similar way by dropping a perpendicular from $C$ to the extension of $AD$.​
To find the angles of a triangle, we can use the law of cosines or the law of sines. In this case, since we are given the value of angle A and the relationship between the sides, we can use the law of cosines.
According to the law of cosines, we know that in a triangle with sides a, b, and c and angle A opposite of side a, the following equation holds: a^2 = b^2 + c^2 - 2bc\cos A.
Substituting in the given values, we get:
\left(\frac{b+c}{2}\right)^2 = b^2 + c^2 - 2bc\cos \alpha
Simplifying, we get:
b^2 + c^2 + 2bc - 4bc\cos \alpha = 0
Using the quadratic formula, we can solve for b or c. However, since we are given that B\geqslant C, we can assume that c is the longer side and b is the shorter side. Therefore, we can solve for b using the negative root.
b = c(2\cos \alpha - 1)
Now, to find angles B and C, we can use the law of sines. According to the law of sines, in a triangle with sides a, b, and c and angles A, B, and C opposite of their respective sides, the following equation holds: \frac{\sin A}{a} = \frac{\sin B}{b} = \frac{\sin C}{c}.
Substituting in the values we have found for a and b, we get:
\frac{\sin \alpha}{\frac{b+c}{2}} = \frac{\sin B}{b}
\sin B = \frac{2\sin \frac{\alpha}{2}}{2\cos \alpha - 1}
Using the inverse sine function, we can solve for angle B. Similarly, we can solve for angle C using the same process.
Therefore, the solution for angles B and C is:
B = \arcsin \left( \frac{2\sin \frac{\alpha}{2}}{2\cos \alpha - 1} \right)
C = \arcsin \left( \frac{2\sin \frac{\alpha}{2}}{
FAQ: How to find angles of a triangle
What is the sum of angles in a triangle?
The sum of angles in a triangle is always 180 degrees. This is known as the triangle angle sum theorem.
How do I find the missing angle in a triangle?
To find the missing angle in a triangle, subtract the known angles from 180 degrees. This will give you the measure of the missing angle.
What are the different types of triangles based on their angles?
There are three types of triangles based on their angles: acute, right, and obtuse. An acute triangle has all angles less than 90 degrees, a right triangle has one angle that is exactly 90 degrees, and an obtuse triangle has one angle that is greater than 90 degrees.
How do I use the Pythagorean theorem to find angles in a right triangle?
The Pythagorean theorem states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides. You can use this theorem to find missing angles in a right triangle by solving for the unknown side using the theorem and then using trigonometric functions to find the angle.
Can I use trigonometry to find angles in any triangle?
Yes, you can use trigonometry to find angles in any triangle by using the sine, cosine, or tangent ratios. These ratios relate the lengths of the sides of a triangle to its angles. By using these ratios, you can solve for the missing angles in any triangle.
