How to find composition of f ° g and g ° f ?
  • MHB
  • Thread starter Henry R
  • Tags
    Composition
In summary, given the functions $f: \mathbb{R} \to \mathbb{R}$ and $g: \mathbb{R} \to \mathbb{R}$, the composition $f \circ g$ is found by replacing the variable in the definition of $f(x)$ with the definition of $g(x)$. Similarly, $g \circ f$ is found by replacing the variable in the definition of $g(x)$ with the definition of $f(x)$. In the given examples, $f \circ g = \log(\log\log(x + 10)+3)$ and $g \circ f = \log(\log(x+3)+10)$.
Henry R
25
Let f and g be function from the positive integer defined by the following pairs f : N →R,g∶N →R. Find the composition f ° g and g ° f.A)
F(n) = log(n+3)
g(n) = log log(n + 10)
B)
F(n) = n log(n+2)
g(n) = n^(1.1)
Could you guys give me answer? Anybody? Please..
Here is my answer for the other question...
f(n)= n + 60 g(n) = 100n
and my answer is this ;
f ° g = 100n + 60
g ° f = 100 ( n + 60 )
= 100n + 6000.
So, can you guys answer the question of A and B?
Mathematics news on Phys.org
If a factory $X$ converts iron ore into iron and you want to use that iron somewhere else, you would need to find another factory that takes iron as input. It won't work to find a factory $Y$ that converts cotton into clothes and try to combine them as in $Y\circ X$. Similarly, you can't feed the output of $f$ into $g$ because $f$ outputs real numbers, such as $\pi$ and $e$, and $g$ expects natural numbers as input.
I assume that in $f\circ g$ the function $g$ is applied first. This is the most prevalent convention, and your example with $f(n)= n + 60$ and $g(n) = 100n$ follows it. However, there are some sources that use the opposite order.
If $f:\Bbb R\to\Bbb R$ and $g:\Bbb R\to\Bbb R$, then the rule of finding $f\circ g$ is the following. Write the definition of $f(x)$ and replace $x$ with the definition of $g(x)$. By definitions I mean the right-hand sides of equalities defining $f$ and $g$. So, in A) the definition of $f(x)$ is $\log(x+3)$ and the definition of $g(x)$ is $\log\log(x + 10)$. Replacing every occurrence of $x$ in the first expression by the second expression, we get $\log(\log\log(x + 10)+3)$. Now I suggest you try finding $g\circ f$.
Note also that in mathematics lowercase and uppercase letters may denote different entities, so $f$ and $F$ may well be different functions and should not be confused.
FAQ: How to find composition of f ° g and g ° f ?
How do I find the composition of f ° g?
To find the composition of f ° g, you must first evaluate the inner function (g) and then use the result as the input for the outer function (f). This can be written as f(g(x)).
What is the difference between f ° g and g ° f?
The difference between f ° g and g ° f is the order in which the functions are applied. In f ° g, g is the inner function and f is the outer function, while in g ° f, f is the inner function and g is the outer function.
How do I evaluate f ° g and g ° f?
To evaluate f ° g, you must first evaluate the inner function (g) and then use the result as the input for the outer function (f). To evaluate g ° f, you must first evaluate the inner function (f) and then use the result as the input for the outer function (g).
Can I interchange the order of functions in f ° g and g ° f?
No, the order of functions cannot be interchanged in f ° g and g ° f. This is because the composition of functions is not commutative, meaning the order in which the functions are applied affects the result.
How can I use the composition of functions in real life?
The composition of functions is commonly used in many fields, such as physics, engineering, and economics, to model and solve complex problems. For example, in physics, the composition of functions can be used to calculate the position, velocity, and acceleration of an object in motion.
