How to find eigenvectors of ugly transfer matrices in stat mech
In summary, the conversation discusses struggling with finding eigenvalues and eigenvectors using the transfer matrix method in statistical mechanics. A trick is mentioned where the lattice gas model can be mapped to the Ising model, allowing for the use of known results to solve the problem. Another trick is mentioned where the transfer matrix is rewritten in terms of x and y, and the eigenvalues can then be found using a quadratic equation. The conversation ends with the discussion of a solution that involves setting (xy - 1/x) equal to 2 sinh(theta) and using the resulting solution to find the matrix element, which leads to the desired result.
paco_uk
I'm trying to use the transfer matrix method in statistical mechanics but I'm struggling with the algebra so I'd like to know if there is a simpler way to find the eigenvalues and eigenvectors of a matrix.
For example, studying the lattice gas model produces the transfer matrix:
[tex]
T = \left( \begin{array}{cc}
1 & e^{\beta \mu /2} \\
e^{\beta \mu /2} & e^{\beta ( J - \mu)} \end{array} \right)
[/tex]
It's not too hard to find the eigenvalues, although they don't look very nice:
[tex]
\lambda = \frac{1 + e^{\beta (J + \mu)}}{2} \pm \sqrt{4e^{\beta \mu} + (1-e^{\beta(J+\mu)})^2}
[/tex]
When it comes to the eigenvectors it seems like a hopeless case:
[tex]
e^{\beta \mu /2} & e^{\beta ( J - \mu)} \end{array} \right) \left( \begin{array}{c}
a \\
b \end{array} \right) = \lambda
a \\
[/tex]
The algebra involved here seems unmanageable, especially as I'm supposed to be able to do this under exam conditions.
I'm supposed to be able to show that:
[tex]
\langle n_i \rangle = \frac{1}{1+e^{-2 \theta}}
[/tex]
where
[tex]
\sinh (\theta ) = \exp(\frac{1}{2} \beta J) \sinh (\frac{1}{2} \beta [J + \mu])
[/tex]
I think that [tex] \langle n_i \rangle [/tex] is given by:
[tex]
\langle n_i \rangle = \langle 0 | \mathbf{C} | 0 \rangle
[/tex]
where [tex] | 0 \rangle [/tex] is the eigenvector corresponding to the largest eigenvalue and:
[tex]
C = \left( \begin{array}{cc}
0 & 0 \\
0 & 1 \end{array} \right)
[/tex]
In fact the examiners report for this question suggests that it is not even necessary to find the eigenvalues of T which is why I am wondering if there is some clever way to spot the eigenvectors without going through all the algebra?
A similar question on the Potts model said something about guessing the eigenvectors from the symmetry of the matrix but I wouldn't know how to start.
My best guess at the short cut would be to realize that the lattice gas hamiltonian can be mapped to the Ising model hamiltonian. Hence, if you know the eigenvectors of the Ising model transfer matrix you can find the eigenvectors of the lattice gas matrix.
The mapping between the models is that if [itex]n_i[/itex] is the occupation of site i in the lattice gas model, then the relation [itex]s_i = 2n_i - 1[/itex] gives you the spin [itex]s_i[/i] at site i. You can thus map the lattice gas to the ising model and use all the known results for the Ising model to solve the problem.
If that's not how they want you to do it, then perhaps you could post the entire problem for us?
Thanks, that's a useful thing to know.
In fact, I came across their solution to this specific question today (that always seems to happen the day after I post a question here). It seems to be more of a neat trick that works here rather than being a generally applicable principal like mapping between models as you suggest. I'll post it anyway in case it's useful to anyone.
Writing [itex] x=e^{\beta \mu /2} [/itex] and [itex] y=e^{\beta J} [/itex], the transfer matrix becomes:
[tex]
1 & x \\
x & x^2 y \end{array} \right)
[/tex]
Then writing [itex] |0 \rangle = (u,v)^T [/itex], we have
[tex]
\begin{eqnarray}u+xv = \lambda_0 u \\
xu + x^2 y v = \lambda_0
\end{eqnarray}
[/tex]
Eliminating [itex]\lambda_0[/itex] and rearranging gives:
[tex]
0=\left( \frac{u}{v} \right)^2 +\left( xy -\frac{1}{x} \right) \left(\frac{u}{v} \right) -1
[/tex]
with solution
[tex]
\left(\frac{u}{v} \right) = -1/2 \left( xy - \frac{1}{x} \right) \pm \sqrt{\left( xy - \frac{1}{x} \right)^2 +4}
[/tex]
Now the trick is to let [itex] ( xy - 1/x) =2 \sinh{\theta} [/itex] which leads to the solution:
[tex]
\left(\frac{u}{v} \right) = e^{\pm \theta}
[/tex]
where I guess the choice of sign determines which of the eigenvectors is being considered.
With C defined as in my original post, the matrix element is just [itex]u^2[/itex]. Along with the normalisation condition [itex]u^2+v^2=1[/itex], this gives the result:
[tex]
[/tex]
and the definition of [itex]\sinh \theta[/itex] matches that in the OP.
FAQ: How to find eigenvectors of ugly transfer matrices in stat mech
1. How do I determine which transfer matrix to use in finding eigenvectors for stat mech calculations?
The transfer matrix used in finding eigenvectors for stat mech calculations is typically the Boltzmann matrix, which represents the probabilities of transitioning between different states of a system.
2. Can I use any method to find eigenvectors of transfer matrices in stat mech?
Yes, there are several methods that can be used to find eigenvectors of transfer matrices in stat mech, including the power method, inverse iteration, and QR algorithm.
3. What are the key properties of eigenvectors in stat mech calculations?
Eigenvectors in stat mech calculations represent the stationary states of a system, where the probabilities of transitioning between different states do not change over time. They also have corresponding eigenvalues that represent the rate at which the system transitions between states.
4. How can I efficiently find eigenvectors of large and complex transfer matrices in stat mech?
One way to efficiently find eigenvectors of large and complex transfer matrices in stat mech is to use numerical methods and algorithms, such as the Lanczos algorithm, which can handle high-dimensional matrices and reduce the computational complexity.
5. Can I use eigenvectors of transfer matrices to predict the behavior of a system in stat mech?
Yes, eigenvectors of transfer matrices can be used to predict the long-term behavior of a system in stat mech, as they represent the stable states of the system and their corresponding eigenvalues determine the probability of transitioning between these states.
