How to find emissivity of tungsten from ln graph?
In summary, the conversation discussed a lab where the goal was to find the emissivity of a tungsten filament. The method involved measuring voltage and current, plotting Power vs Temperature^4, and using the slope, surface area, and Boltzman's constant to find the emissivity. However, the expected method was to plot ln(P) vs ln(T) and find the emissivity using the equation P = aT^n. The conversation also mentioned finding the surface area of the tungsten element and determining the value of a. With all the necessary information, the emissivity can be calculated successfully.
dinospamoni
92
I'm doing a lab where I'm trying to find the emissivity of a tungsten filament. I measured voltage and current of a bulb with a tungsten filament and found the power. Then I plotted Power vs Temperature^4 and used the slope along with surface area and Boltzman's constant to find the emissivity. But I am expected to plot ln(P) vs ln(T) and find the emissivity and I can't quite figure out how to do that.
I plotted it bas on this equation
ln(P) = ln(a) +n ln(T)
which was derived from the equation
P = aT^n
I'm lost for this part. I've found everything else I'm supposed to except for this. i found n to be close enough to 4 and can find a from the intercept, but I'm not really sure what a stands for. Is that the emissivity?
It looks like a=Aeσ. Finding the Surface area of the tungsten element might be tricky. Perhaps you need to measure the resistance of the element, estimate length and determine surface area.
Ah of course that makes tons of sense. I have the surface area so now I have everything I need. Thanks!
I would recommend using the Stefan-Boltzmann law to find the emissivity of tungsten from an ln graph. This law states that the power (P) emitted by a blackbody is directly proportional to the temperature (T) raised to the fourth power, with the constant of proportionality being the Stefan-Boltzmann constant (σ). Therefore, the equation can be written as P = σT^4.
To find the emissivity (ε) of tungsten from an ln graph, you can rearrange the equation to ln(P) = ln(σ) + 4ln(T) + ln(ε). By plotting ln(P) vs ln(T), the slope of the line will be equal to 4, and the y-intercept will be ln(σ) + ln(ε). Therefore, you can find the emissivity by subtracting ln(σ) from the y-intercept.
It is important to note that the value of a in your equation, ln(P) = ln(a) + n ln(T), is not the emissivity. It is a constant that takes into account the surface area, distance from the source, and other factors. Therefore, it is not appropriate to use this value to find the emissivity.
In summary, to find the emissivity of tungsten from an ln graph, you can use the Stefan-Boltzmann law and plot ln(P) vs ln(T). The slope of the line will be 4, and the y-intercept can be used to find the emissivity by subtracting ln(σ) from it.
Related to How to find emissivity of tungsten from ln graph?
1. What is emissivity?
Emissivity is a measure of how well a material emits thermal radiation. It is typically represented by the Greek letter epsilon (ε) and ranges from 0 to 1, with 0 being a perfect reflector and 1 being a perfect emitter.
2. Why is it important to find the emissivity of tungsten from ln graph?
Tungsten is commonly used in high-temperature applications, such as in light bulbs and heating elements. Knowing its emissivity is important for accurately predicting its thermal behavior and optimizing its performance in these applications.
3. How is the emissivity of tungsten determined from an ln graph?
The emissivity of tungsten can be determined by plotting the natural log of the tungsten's thermal radiation intensity against its temperature and finding the slope of the resulting line. This slope represents the emissivity value.
4. What factors can affect the emissivity of tungsten?
The emissivity of tungsten can be affected by several factors, including its surface roughness, temperature, and wavelength of the thermal radiation being emitted.
5. Can the emissivity of tungsten be accurately determined from only one ln graph?
No, it is recommended to take multiple measurements and plot them on an ln graph to ensure accuracy. This will also help identify any outliers or errors in the data.
  • Mechanics
