How to find initial velocity with only an angle and distance?
In summary: This problem expects the student to know the equation for accelerated motion, specifically in terms of velocity and angle. [The student is expected to know this because it is a standard equation that is covered in physics]The student is then expected to use this equation to solve for the velocity of the golf ball. [The student is expected to solve for the velocity because it is a question about projectiles]
Tracy Reynoso
I am in Algebra 2 and the homework asks a question:
"You and a friend arw driving golf balls at a driving range. If the angle of elevation is 30 degrees and the ball travels 625 feet horizontally, what is the initial velocity of the ball?"
It seems strange this would be asked in an algebra course since the formulas to solve it come from physics, specifically the equations for accelerated motion.
There was nothing in this chapter about projectiles? There is a standard equation relating velocity, angle, and range. It seems to me in an algebra course that that formula would accompany this problem, in which case all you have to do is plug in the two known things (angle and range) and solve for velocity.
You seem to have removed the homework template and included only the question. These forums are intended to provide assistance with homework. Not to do it for you.
What is your thinking about the problem? With what you have been given, are there any useful quantities that you can calculate?
In questions of this sort, one typically ignores air resistance and considers only the fixed acceleration of gravity. [With air resistance included, the problem involves not just algebra but differential equations as well].
The student is typically expected to know the acceleration of gravity, approximately 32 feet per second per second. [In physics, one would typically be trained to convert units of measurement and work in meters and seconds. But in Algebra 2, we can skip the conversion and continue to work in feet and seconds]
Related to How to find initial velocity with only an angle and distance?
What is initial velocity?
Initial velocity is the velocity of an object at the beginning of its motion. It is the speed and direction at which the object is moving before any external forces act upon it.
Why is it important to find initial velocity?
Finding the initial velocity of an object is important because it allows us to understand the motion of the object and make predictions about its future movement. It is a crucial component in solving problems related to motion and dynamics.
Can initial velocity be calculated with only an angle and distance?
Yes, it is possible to calculate the initial velocity of an object with only an angle and distance. This can be done using the formula v0 = √(d * g / sin2θ), where v0 is the initial velocity, d is the distance, g is the acceleration due to gravity, and θ is the angle of launch.
What are the units for initial velocity?
The units for initial velocity depend on the units used for distance and time. For example, if distance is measured in meters and time is measured in seconds, then the units for initial velocity would be meters per second (m/s).
Can initial velocity be negative?
Yes, initial velocity can be negative. This means that the object is moving in the opposite direction of the chosen positive direction. It is important to pay attention to the signs in the calculation to accurately represent the direction of the object's motion.
