How to find large modulus on Casio fx-991 MS
In summary, to find modulus using a calculator, divide the dividend by the divisor, note the answer and discard all decimals, then multiply the answer by the divisor and subtract it from the original dividend. For larger numbers, you can break down the problem into smaller parts to make it easier to calculate.
anes
Hi pals,
I am looking to find a modulus calculation using my casio fx-991 ms calculator
i know how to find modulus using small numbers
eg: 7 mod 3 = 1. This because 7 = 3(2) + 1, in which 1 is the remainder. To do this process on a simple calculator do the following: Take the dividend (7) and divide by the divisor (3), note the answer and discard all the decimals -> example 7/3 = 2.3333333, only worry about the 2. Now multiply this number by the divisor (3) and subtract the resulting number from the original dividend. so 2*3 = 6, and 7 - 6 = 1, thus 1 is 7mod3
but i need to find
5^36 mod 97
it's answer is 50
but when i do i don't get the full number in calculator it show 1.4500000x 10^34
but i don't know how to calculate mod use this type of result .
please advise me
Thanks
Anes
Mathematics news on Phys.org
You'll have to do some calculations yourself, I think.
5^36 = (5^3)^12 = 125^12
125^12 mod 97 = (125 mod 97)^12 mod 97 (using computer notation, not mathematical notation).
125 mod 97 is easy to evaluate.
You can repeat those steps until the number is small enough for the calculator.
Dear Mentor ,
I don't get your point fully . please solve (28)^12 mod 97 in next step.
Thanks
Anes
(28)^12 = (28^2)^6 for example. You can just repeat that step.
Thanks dear mentor i got the ultimate answer now
(28^2 mod 97)^6 mod 97 = (8)^6 mod 97 = 262,144 mod 97
which can find by
262,144/97 = 2702.515 take this 2702 as X
262,144 - 97*2702( we call it as X) = 50 (Ans)
Thanks a lot i believe my answer is good for those who look in futureAnes
For make this problem easeful , i gave 1 more example
5^58 mod 97
(5^2 mod 97)^29 mod 97
(25 mod 97)^29 mod 97
(25)^29 mod 97
25. (25)^8 mod 97 // because 29 cannot be factorized further
25.(25^4 mod 97)^7 mod 97
25.(6)^7 mod 97
25.91 mod 97
= 44(Ans)
Hope all understand
Thanks alot
How can I get the solutions for solving (7^12) mod 71 ?? Correct answer is: 4, But I m getting a wrong answer...Anybody help me.
Please open a new thread for new questions, this thread is from 2014. Anyway, the existing posts should help.
Related to How to find large modulus on Casio fx-991 MS
1. How do I access the modulus function on Casio fx-991 MS?
To access the modulus function on Casio fx-991 MS, press the SHIFT button followed by the "%" button. This will bring up the modulus symbol on your calculator's display.
2. What is the modulus function used for?
The modulus function, denoted by the symbol "%", is used to find the remainder of a division between two numbers. It is commonly used in mathematical and scientific calculations, as well as in computer programming.
3. Can I find the modulus of decimal numbers on Casio fx-991 MS?
Yes, Casio fx-991 MS allows you to find the modulus of decimal numbers. Simply enter the decimal numbers using the decimal point button and then use the modulus function as usual.
4. How do I find the modulus of negative numbers on Casio fx-991 MS?
To find the modulus of negative numbers on Casio fx-991 MS, you need to use parentheses. For example, to find the modulus of -5, you would enter "( -5 ) %". This will give you the result of 5.
5. Is there a shortcut to find the modulus of a number on Casio fx-991 MS?
Yes, Casio fx-991 MS has a shortcut to find the modulus of a number. Simply enter the number, followed by the modulus symbol (%), and then press the "=" button. This will give you the remainder of that number divided by 1.
  • General Math
  • Linear and Abstract Algebra
