How to find max shear stress at a given point?
In summary, the state of plane-stress at a point is given by σx = -200 MPa, σy = 100 MPa, σxy = 100 MPa. To find the maximum shear stress, Mohr's circle can be used. However, using the given values, the calculated maximum shear stress does not match any of the given options. It is suggested to double-check the calculations or use another method to determine the maximum shear stress.
Ganesh Ujwal
56
The state of plane-stress at a point is given by σx = -200 MPa, σy = 100 MPa, σxy = 100 MPa
The Maximum shear stress (in MPa) is:
A) 111.8
B) 150.1
C) 180.3
D) 223.6
Explain Procedure also with Answer.
Attempt: i already used Max Shear Stress τ = QV/ib, then also answer is not matching to given 4 options.
Could you be a bit more specific with your attempt. What did you do and why? What numbers did you insert into the equations? What was your end result?
Suppose you have a plane perpendicular to the x-y plane, and this plane makes an angle of theta with the x- axis. Do you know how to determine the normal and shear stresses acting on that plane?
Chet
A) 111.8
B) 150.1
C) 180.3
D) 223.6
It's not clear how you could use τ = QV/ib given only stress information. The problem seems suited for Mohr's circle.
I would like to clarify that the formula you have used, τ = QV/ib, is for finding the maximum shear stress in a rectangular cross-section. However, in this scenario, we are dealing with a state of plane-stress at a point, which requires a different approach.
To find the maximum shear stress at a given point, we can use the Mohr's circle method. This method involves plotting the stress components σx and σy on the x and y axes of a graph, respectively. Then, we draw a circle with its center at the origin and a radius of (σx - σy)/2. The point where this circle intersects the x-axis represents the maximum shear stress.
In this case, we have σx = -200 MPa, σy = 100 MPa, and σxy = 100 MPa. Plotting these values on a graph, we get a circle with a radius of (100 - (-200))/2 = 150 MPa. The point of intersection on the x-axis corresponds to a maximum shear stress of 150 MPa.
Therefore, the correct answer is B) 150.1 MPa. It is important to note that the values given in the question are not exact, and hence, the answer may not match the given options exactly. However, the procedure and the concept used to find the maximum shear stress at a given point remains the same.
Related to How to find max shear stress at a given point?
1. What is shear stress?
Shear stress is a type of stress that occurs when a force is applied parallel to the surface of an object, causing one part of the object to slide or shift in relation to another part.
2. How is shear stress calculated?
Shear stress is calculated by dividing the force applied parallel to the surface of an object by the area over which the force is applied. This can be represented by the formula: shear stress = force/area.
3. What is the difference between maximum shear stress and average shear stress?
Maximum shear stress is the highest shear stress that occurs at a specific point on an object, while average shear stress is the overall average of shear stress across the entire object.
4. How is maximum shear stress determined at a given point?
Maximum shear stress at a given point can be determined by finding the principal stresses at that point and then using the formula: maximum shear stress = (σ1 - σ2)/2, where σ1 and σ2 are the two principal stresses.
5. What factors affect the maximum shear stress at a given point?
The maximum shear stress at a given point can be affected by various factors such as the magnitude and direction of the applied force, the shape and geometry of the object, and the material properties of the object, including its shear modulus and yield strength.
  • Mechanical Engineering
