How to find p and q (Charpit method) for this equation
  • Thread starter lotusquantum
  • Tags
    Method
In summary: Therefore, the general solution is given by: u(x,y) = c where c is a constant. In summary, to find the general solution for the given equation, we can use the method of characteristics and solve the system of equations given by the charpit equations. Doing so gives us the solution u(x,y) = c, where c is a constant.
lotusquantum
[tex] 2uq^2+y^2(q-p)=0[/tex]
[tex]p= \partial u/\partial x [/tex]; [tex] q= \partial u/\partial y [/tex]
We get the charpit equations:
[tex]\frac{dx}{-y^2}=\frac{dy}{4uq+y^2}=\frac{du}{-py^2+q(4uq+y^2)}=\frac{dp}{-2pq^2}=\frac{dq}{-2y(q-p)-2q^3}[/tex]
I don't know how to find the value of p and q ??
(i have tried the following ways but i cannot:
from the original equation we have: [tex] (q-p) =-\frac{2uq^2}{y^2} [/tex]
substitute into the last pair equation [tex]\frac{dq}{-2y(-\frac{2uq^2}{y^2})-2q^3}=\frac{dp}{-2pq^2}[/tex]
or [tex]\frac{dq}{dp}=\frac{1}{p}(\frac{-2u}{y}+q) => q = \frac{2u}{y}+p.c1[/tex]
but i don't know how to find p? because any pairs will lead to a complicated equation. please experts help! thanks )
To find the values of p and q, we can use the method of characteristics. This involves solving the system of equations given by the charpit equations.
First, we can rearrange the original equation to get:
2uq^2 + y^2q - y^2p = 0
Now, using the charpit equations, we can set up the following system of equations:
dx = -y^2 ds
dy = 4uq + y^2 ds
du = -py^2 + q(4uq + y^2) ds
dp = -2pq^2 ds
dq = -2y(q-p) - 2q^3 ds
We can then solve for dp/ds and dq/ds by substituting the values of dx and dy into the equations for dp and dq. This gives us:
dp/ds = 2y^2p + 8uq^2 + 4q^3
dq/ds = 2y(q-p) - 4q^3
Next, we can substitute these values into the equations for du and dq to get:
du/ds = -py^2 + q(4uq + y^2)
dq/ds = -2y(q-p) - 2q^3
Now, we can solve for p and q by setting the equations for du/ds and dq/ds equal to 0. This gives us:
0 = -py^2 + q(4uq + y^2)
0 = -2y(q-p) - 2q^3
Solving for p and q in terms of u and y, we get:
p = \frac{q(4uq + y^2)}{y^2}
q = -\frac{2y(q-p)}{2q^2 + y^2}
Substituting these values back into the original equation, we get:
2uq^2 + y^2q - y^2(\frac{q(4uq + y^2)}{y^2}) = 0
2uq^2 + y^2q - 4uq^2 - y^2q = 0
-2
FAQ: How to find p and q (Charpit method) for this equation
What is the Charpit method for finding p and q in an equation?
The Charpit method is a technique used to solve partial differential equations by transforming them into a system of ordinary differential equations. This method is particularly useful for finding the general solution of a partial differential equation.
2. How do I apply the Charpit method to find p and q?
To apply the Charpit method, you first need to write the given partial differential equation in the form of a system of ordinary differential equations. Then, you need to transform the system by introducing new variables and using the Charpit equations to eliminate the arbitrary functions p and q. This will result in a system of equations that can be solved to find the values of p and q.
3. Can the Charpit method be used for all types of partial differential equations?
No, the Charpit method is only applicable to certain types of partial differential equations, such as those that are linear and have constant coefficients. It may not work for more complex equations or those with variable coefficients.
4. Is there a specific order in which I should solve the Charpit equations to find p and q?
Yes, the Charpit equations should be solved in a specific order to obtain the correct values of p and q. First, you should solve for the arbitrary function p, and then use this value to solve for q. Solving the equations in any other order may result in incorrect values.
5. Are there any limitations or drawbacks to using the Charpit method?
One limitation of the Charpit method is that it may not always provide a general solution to a partial differential equation. In some cases, it may only give a particular solution. Additionally, the method can be quite complex and time-consuming, making it difficult to use for more complicated equations.
