How to find the answer sin 120.
  • MHB
  • Thread starter tmt1
  • Tags
    Sin
In summary, the formula for finding the sine of an angle is sin(x) = opposite/hypotenuse, where x is the given angle. To find the value of sin 120 degrees, you can use a scientific calculator or a trigonometric table, or utilize the half-angle formula for sine (sin(x/2) = ±√[(1-cosx)/2]). You can also find the sine of 120 degrees without a calculator by using the half-angle formula or knowing the trigonometric values for common angles. The sine of 120 degrees is negative because it falls in the second quadrant of the unit circle. Knowing the sine of 120 degrees can have practical applications in fields such as engineering, physics, and
tmt1
234
I was reading on a forum that $$sin120$$ is equal to$$ sin60$$.
How is this? Shouldn't$$ sin120$$ equal $$sin60 + sin60$$?
Mathematics news on Phys.org
How is this? ...
Good evening,
use the unit circle:
FAQ: How to find the answer sin 120.
What is the formula for finding the sine of an angle?
The formula for finding the sine of an angle is sin(x) = opposite/hypotenuse, where x is the given angle.
How do I find the value of sin 120 degrees?
To find the value of sin 120 degrees, you can use a scientific calculator or a trigonometric table. Alternatively, you can use the half-angle formula for sine (sin(x/2) = ±√[(1-cosx)/2]) to simplify the calculation.
Can I find the sine of 120 degrees without a calculator?
Yes, you can find the sine of 120 degrees without a calculator by using the half-angle formula or by using the unit circle and knowing the trigonometric values for common angles (such as 30, 45, and 60 degrees).
Why is the sine of 120 degrees negative?
The sine of 120 degrees is negative because it falls in the second quadrant of the unit circle, where the sine values are negative. This means that the opposite side of the triangle is below the horizontal axis, resulting in a negative ratio (opposite/hypotenuse).
What is the practical application of knowing the sine of 120 degrees?
Knowing the sine of 120 degrees can be useful in various fields such as engineering, physics, and astronomy. For example, it can be used to calculate the height of a building or the trajectory of a projectile. It can also be used to determine the angular velocity of a rotating object.
