How to find the coefficient of kinetic friction?
In summary, the child slides down a slide with a coefficient of kinetic friction of 0.5. When there is no friction, the child's kinetic energy is KE_o and when there is friction, the child's kinetic energy is KE_f. The change in gravitational potential energy during the trip is determined by the length of the slide and the mass of the child.
audrey1203
A child slides down a slide with a 28° incline, and at the bottom her speed is precisely half what it would have been if the slide had been friction-less. Calculate the coefficient of kinetic friction between the slide and the child.
Knowns:
28°
speed=V/2
##\Sigma F=ma##
##{ F }_{ fr }={ \mu }_{ k }{ F }_{ N }##
##{ v }^{ 2 }={ v }_{ 0 }^{ 2 }+2a(x-{ x }_{ 0 })##
##\Sigma { F }_{ y }=ma=0##
##{ F }_{ N }-mgcos\sigma =0##
##{ F }_{ N }=mgcos\sigma##
##{ \Sigma F }_{ x }=ma##
##-{ F }_{ fr }+mgsin\sigma =ma##
##{ F }_{ fr }=\frac { ma-mgsin\sigma }{ -1 } ##
##{ F }_{ fr }=-ma+mgsin\sigma ##
##-ma+mgsin\sigma ={ \mu }_{ k }mgcos\sigma ##
##\frac {-ma+mgsin\sigma }{ mgcos\sigma } ={ \mu }_{ k }##
##\frac { -a+gsin\sigma }{ gcos\sigma } ={ \mu }_{ k }##
WELCOME TO PF!
OK. But you can see that solving for ##\mu_k## here does not seem to help much since you don't know the value of the acceleration ##a##.
Instead of using the first equation above to solve for ##\mu_k##, think of the equation as giving you the acceleration when friction is present.
What would this equation look like if there was no friction?
How must the acceleration with friction compare to the acceleration without friction in order for the final speed to be cut in half with friction?
Hi audrey1203, Welcome to Physics Forums!
One way to tackle the problem is to look at it in terms of kinematics: forces and accelerations, which is what you've shown. Another way is to consider an energy approach.
Since KE is proportional to the square of the velocity, and if the velocity with friction present is one half that of when there's no friction, then the KE with friction must be 1/4 that of the frictionless case. That is, ##KE_o = 4 KE_f##, where ##KE_o## is the kinetic energy of the child at the bottom of the slide when no friction is present , and ##KE_f## is the kinetic energy when friction is present. You should confirm that for yourself by writing out the expressions for KE when the velocity is v and v/2 and comparing the results.
Hint: If you choose an arbitrary value for the length of the slide (maybe call it L) then you can determine the change gravitational PE during the trip and any energy loss due to friction since you know how to find the friction force. All the unknowns (like L and the mass of the child) should disappear in the algebra along the route :smile:
Related to How to find the coefficient of kinetic friction?
1. How do you measure the coefficient of kinetic friction?
The coefficient of kinetic friction can be measured by conducting an experiment where an object is placed on a surface and a force is applied to make it move at a constant velocity. The force required to keep the object moving is divided by the weight of the object to calculate the coefficient of kinetic friction.
2. What factors affect the coefficient of kinetic friction?
The coefficient of kinetic friction is affected by several factors, including the nature of the surfaces in contact, the roughness of the surfaces, and the force applied. Other factors such as the temperature and the presence of lubricants can also affect the coefficient of kinetic friction.
3. How does the coefficient of kinetic friction differ from the coefficient of static friction?
The coefficient of kinetic friction is the measure of the resistance between two surfaces in motion, while the coefficient of static friction is the measure of the resistance between two surfaces at rest. The coefficient of static friction is typically higher than the coefficient of kinetic friction.
4. Can the coefficient of kinetic friction be negative?
No, the coefficient of kinetic friction cannot be negative. It is always a positive value, as it represents the ratio of the force required to keep an object moving to the weight of the object. A negative value would indicate that the force required to keep the object moving is less than its weight, which is not physically possible.
5. How does the coefficient of kinetic friction affect the motion of objects?
The coefficient of kinetic friction determines the amount of resistance an object experiences when moving across a surface. A higher coefficient of kinetic friction means that more force is required to keep the object moving at a constant velocity, while a lower coefficient of kinetic friction means that less force is needed. This can impact the speed and acceleration of objects on different surfaces.
