How to find the depth of immersion of this boat model?
In summary, the pontoon has curvilinear edges (subparabolic edges) on each side. The figure of the pontoon is shown below. The depth of immersion is to be found by calculating the displacement volume and then finding the height of the water that rises, called the depth of immersion.
PrincessIceFall
50
So I am trying to find the depth of immersion of this particular boat model, which has curvilinear edges (subparabolic edges) on each side. The figure of the pontoon is shown below
So now when I place this pontoon in water, the height of the water that rises, called the depth of immersion is to be found. I already know how to calculate the displacement volume, but I have no idea how to find the depth of immersion. Below are the steps taken to find the displacement volume
1. Volume of body
I assumed the whole body to be a rectangle and calculated the area of the rectangle first: B*h
And then, since the curves are subparabolic, it is defined by the equation:
y = (h/b^2)*x^2
Integrating the above equation, gives the area under the curve to be:
bh/3
So subtracting : 2*(bh/3) from (B*h) will give the cross sectional area which
C.S.A = (B*h)-(2*(bh/3))
Multiplying this C.S.A with the length of the pontoon (say L) will give the volume
V = (C.S.A)*L = [(B*h)-(2*(bh/3))] * L
So now that volume of the body is known, the following steps are taken to find the displacement volume
2. Density of body
Density = mass of body / Volume
Note: The mass was found by weighing the pontoon on a weighing machine
3. Specific weight of body
Specific weight of body = density of body * g
Note: g = 9.81 m/s^2
4. Weight of body
Weight of body = Specific weight of body * Vbody
5. Weight of water displaced
Weight of displaced water = Specific weight of water * Displaced volume
Note: Specific weight of water = 9810 N/m^3
6. Archimedes principle
According to Archimedes Principle the weight of the body acting downwards is equal to the weight of displaced acting upwards, so
Wbody = 9810 * Vdisp
7. Displaced Volume
And so the displaced volume of water is given by
Vdisp = Wbody/9180
Now another equation for the displacement volume is:
Vdisp = [(B'*h')-(2*(b'h'/3))] * L
h' is the depth of immersion
and B' is the top width at this displaced volume
The problem is that there are two unknowns in the above equation and I just can't figure out how to find the depth of immersion here. If anyone has any idea please please let me know.
It's not clear from your explanation if you know the weight of the vessel.
In general, in order to find the waterline at which a vessel floats, you need to know the weight (or mass) of the vessel and the location of its center of gravity.
A set of curves which give the displacement, the location of the center of buoyancy, the height of the metacenter, etc., for various drafts (or depths of immersion) can be computed for a vessel hull given its shape. This information is known as the curves of form or hydrostatic curves.
I have infact mentioned that the mass of the body was found by weighing the pontoon on a weighing machine.
You have one of the data items I mentioned then. With only the weight of the vessel known, the best you can hope to achieve is to find the mean draft of the vessel by calculation.
You can also experimentally find the location of the longitudinal and transverse center of gravity of the vessel with it out of the water by trying to balance it on a knife edge or by suspending it from two points and measuring the tension in the lines using a dynamometer. By using this information, the LCG and TCG can be calculated. In order to find VCG, you would need to carry out an inclining experiment.
Okay, let's say I do know the location of the centre of gravity. How do you suggest I find the depth of immersion then.
Okay, how would I find the mean draft.
You'll have to assume a draft, make your volume calculation for the hull at that draft, and if the corresponding displacement is different from the weight of the vessel, you'll have to pick a new draft and repeat the calculation. It's a pretty tedious calculation.
Why don't you just put the vessel into some water and measure the draft? The draft can be found a lot quicker than by calculation.
It is something that I am required to do. Of course I can find the draft through the experiment. But I also need to program theoretical equations.
That is not true. The only unknown is h', since:
h' = (h/b^2)*b'^2 --> b' = b*√(h'/h)
B' = A + 2b' = A + 2b*√(h'/h)
So L & Vdisp are known and all others are solely dependent on h', since A, b and h should also be known.
But not easy to isolate h' though:
Vdisp = [(A + 2b*√(h'/h))*h'-2*(b*√(h'/h)h'/3)] * L
Vdisp = [Ah' + √(4b^2/h)*h'^(3/2) - √(4b^2/h)/3*h'^(3/2)] * L
Vdisp/L = Ah' + 2/3*√(4b^2/h) * h'^(3/2)
I am going to have to check this myself. But if what you are saying is right then you are my best-est friend in the world.
I checked it and its correct. And you are right, it is almost impossible to make h' the subject of the formula. One way of doing it is through iterations. Inputting random values of h' until I get the Vdisp I calculated. This could be done through a spreadsheet or plotting a graph.
Related to How to find the depth of immersion of this boat model?
1. What is the definition of "depth of immersion"?
The depth of immersion refers to the distance that an object, in this case a boat model, is submerged in a fluid, usually water.
2. How is the depth of immersion measured?
The depth of immersion can be measured using various methods such as a depth gauge, a water level, or by taking measurements and calculations of the boat's dimensions and comparing it to the waterline.
3. What factors affect the depth of immersion of a boat model?
The depth of immersion of a boat model is affected by its weight, shape, size, and the density of the fluid it is immersed in. Other factors like the center of gravity and buoyancy also play a role.
4. How can I calculate the depth of immersion of a boat model?
To calculate the depth of immersion of a boat model, you will need to know its dimensions, weight, and the density of the fluid it is in. You can then use a formula such as Archimedes' principle to calculate the volume of water displaced and determine the depth of immersion.
5. Why is it important to know the depth of immersion of a boat model?
The depth of immersion of a boat model is important for determining its stability, buoyancy, and weight distribution. It can also help in identifying potential risks or issues with the design of the boat model and make necessary adjustments for safe and efficient operation on water.
10K
  • Mechanical Engineering
  • Other Physics Topics
