How to find the eigenvector for a perturbated Hamiltonian?
In summary: This is an isotropic 2D oscillator whose eigenenergies are given by $$E_n=\hbar\omega(n_x+n_y+1)$$ so the first two excited states are $$| 1,0\rangle ~~~and ~| 1,0\rangle ~~~~E_1=2\hbar\omega$$As for the first excited state, is the eigenvector for the matrix in post #1?I'm guessing you are asking if the eigenvector for the first excited state is the eigenvector of the matrix in post #1. The answer is no, the eigenvector for the first excited state is
happyparticle
456
Find the eigenvalue (first order) and eigenvector (0 order) for the first and second excited state (degenerate) for a perturbated hamiltonian
##H' = kxy##
##H = \frac{p_x^2}{2m} +\frac{p_y^2}{2m} + \frac{1}{2}m \omega^2 x^2 + \frac{1}{2}m \omega^2 y^2 ##
Hi,
I have to find the eigenvalue (first order) and eigenvector (0 order) for the first and second excited state (degenerate) for a perturbated hamiltonian.
However, I don't see how to find the eigenvectors.
To find the eigenvalues for the first excited state I build this matrix
\begin{pmatrix}
\langle 01 | H'| \rangle 01 & \langle 10| H'| \rangle 01 \\
\langle 01 | H'| \rangle 10 & \langle 10| H'| \rangle 10
\end{pmatrix}
= \frac{k \hbar}{2 m \omega}
\begin{pmatrix}
0 & 1 \\
1 & 0
\end{pmatrix}
Thus, I get the eigenvalue ##\pm \frac{k \hbar}{2 m \omega}##, but now I have no idea how to find the eigenvector for the 0 order.
Any help will me appreciate, thank you.
Are you saying that you know how to find the eigenvalues of a 2×2 matrix but you don't know how to find the corresponding eigenvectors? If so, there are plenty of sites that explain how. Just google "How to find the eigenvectors of a two by two matrix" and take your pick.
Likes malawi_glenn
I know how to find the eigenvector for a 2x2 matrix.
However, I'm not sure to understand what an eigenvector (0 order) for the first and second excited state really means.
For example is the eigenvector for the first excited state the eigenvector of the matrix in post #1 ?
This is the nuts and bolts of degenerate perturbation theory. Absent the perturbation (i.e.##H'=0##), $$|n_x,n_y \rangle$$ are exact energy eigenstates so ##|1,0 \rangle## and ##|0,1 \rangle## are exactly degenerate solutions.
With ##H'\neq0## the perturbation theory is an expansion in k solved iteratively. Degenerate solutions can introduce convergence issues unless one selects states with an eye to the next order calculation. This choice is not an exact solution to the full Hamiltonian but it allows uniform convergence for what ensues
Let's backtrack a bit. The perturbed 2×2 Hamiltonian matrix that you have cannot give you a second excited state. Do you see why? You need to expand the dimensionality of your matrix. How are you going to do this?
For the second excited state, ##n = 2##, so the possible states are ##\langle 2,0,0| , \langle2,1,0| , \langle 2,1,1| , \langle 2,1,-1|##
I am a little lost in nomenclature here. This is an isotropic 2D oscillator whose eigenenergies are given by $$E_n=\hbar\omega(n_x+n_y+1)$$ so the first two excited states are $$| 1,0\rangle ~~~and ~| 1,0\rangle ~~~~E_1=2\hbar\omega$$
Hmm, from my course notes we have ##\langle n,l,m| H' | n,l,m \rangle##. Maybe I misunderstood something somewhere.
Or maybe the expression above is only for 1 particle.
happyparticle said:
Hmm, from my course notes we have ⟨n,l,m|H′|n,l,m⟩. Maybe I misunderstood something somewhere.
One can do the problem in cylindrical coordinates but I do not know why one would. What are the notes for explicitly (and what course?). Methinks all is not well with you and quantum?
This is a nice problem applicable in many systems. A few misunderstandings might have happened here.
First, your non-interacting Hamiltonian consists of 2 oscillator
$$ H_{x,y} = p^2_{x,y} + (x,y)^2, $$
where ##(x,y)## can be x or y . All parameters set to 1. Each oscillator has infinite levels. In a perturbation calculation, all levels have to be included. First order perturbation calculation means taking the correlation of all levels with the interaction term ##H^\prime## in to account. Second order perturbation means taking the correlation of the first oder correlations. And so on, applied to all states. What you did (neglecting the correctness) is taking only the first two levels in to account. Hopefully this clarifies the issue.
Second, if you like to use the polar representation ##\langle n,l,m|H^\prime| n^\prime,l^\prime,m^\prime \rangle##, there are probably less than 3 quantum numbers. Your problem lives in 2D space.
Third, a pretty simple thing one can do is to work it out in number space and use that to check the result of your calculation. The Hamiltonian can be written as
$$H = a^{\dagger} a + b^{\dagger} b + h.c. + k x y, $$
where ##a, b## are ladder operators for ##x, y## degrees of freedom. ##x = a^{\dagger} + a##. The interaction term is called dipole coupling. Turning it to quadratic form, you can diagonalize the two coupled oscillator giving ##2 k##-splitting and the collective normal modes.
I hope that helps.
I would take the "first two excited states" to mean (unperturbed) energy levels ##E_1=2\hbar\omega## and ##E_2=3\hbar\omega##.
I would certainly not. This seems very bad nomenclature and pedagogy to me. If we solve in cylindrical coordinates do we ignore angular momentum multiplicity? States are states and levels are levels.
I would say it's an euphemism. We spent the last 3 months deriving equations without further explanation or examples. To be honest I try to apply what I saw without really knowing what I do.
p-waive said:
I hope that helps.
A little bit. However, I thought what I did in post #1 what correct to find the eigenvalue.
I stand corrected. My mistake about the first order corrected eigenvectors.
Thanks for pointing out!
I guess you found your 0-th order eigenvectors which are pretty obvious.
FAQ: How to find the eigenvector for a perturbated Hamiltonian?
What is a perturbated Hamiltonian?
A perturbated Hamiltonian is a Hamiltonian operator that has been slightly altered or perturbed from its original form. This is often done to study the effects of small changes or external influences on a quantum system. The perturbation is usually represented as a small parameter added to the original Hamiltonian.
How do you start finding the eigenvector for a perturbated Hamiltonian?
To find the eigenvector for a perturbated Hamiltonian, you typically start with the eigenvectors and eigenvalues of the unperturbed Hamiltonian. Then, you apply perturbation theory, which provides a systematic way to correct the eigenvalues and eigenvectors to account for the perturbation.
What is the first-order correction to the eigenvector in perturbation theory?
The first-order correction to the eigenvector in perturbation theory is computed by considering the interaction between the unperturbed eigenstates and the perturbation. Mathematically, it involves summing over the contributions from all other unperturbed eigenstates, weighted by the matrix elements of the perturbation and the energy differences between the states.
Can you provide an example of a simple perturbation problem?
Consider a simple quantum harmonic oscillator with a perturbation in the form of a small anharmonic term, such as \( H' = \lambda x^4 \). The unperturbed Hamiltonian has known eigenstates and eigenvalues. Using perturbation theory, you can calculate the first-order corrections to these eigenvalues and eigenvectors by evaluating the matrix elements of \( x^4 \) in the basis of the unperturbed eigenstates.
What are the limitations of perturbation theory?
Perturbation theory is most effective when the perturbation is small compared to the unperturbed Hamiltonian. If the perturbation is too large, the series expansions used in perturbation theory may not converge, and the results may become inaccurate. Additionally, perturbation theory may not be applicable if the system has degenerate states or if the perturbation introduces significant non-linear effects.
