How to find the equilibrium position and potential energy?
In summary, the conversation discusses a problem where a mass is attached to a spring and the equilibrium position, potential energy, and kinetic energy of the system need to be calculated in terms of the height of the mass (x). The solution involves setting the total force to zero and using the equations for kinetic and potential energy to find the equilibrium position and energy values.
KFC
488
Given a setup with spring, the massless spring constant is k, unstretched length of the spring is [tex]L_0[/tex]. A mass m is attaching to the top of the spring. We only know the height of the mass (measuring from the top of the platform) is x, the height of the platform is h. Try to find the equilibrium position of the system, the potential energy and kinetic energy of the system in terms of x.
http://img150.imageshack.us/img150/5247/a101pc3.jpg
2. The attempt at a solution
I setup a coordinate system with the origin on CD line, call the vertical axis X (capital X). The hooke law gives
[tex]mg = -k\Delta X, \qquad \Delta X = x + h - L_0[/tex]
For finding the equilibrium position ([tex]x_0[/tex]), we let [tex]\Delta X = x + h - L_0 = 0[/tex] gives [tex]x_0 = L_0 - h[/tex]
The kinetic energy of the mass is obvious
[tex]E_k = \frac{m}{2}\left(\frac{dX}{dt}\right)^2 = \frac{m}{2}\left[\frac{d(x+h)}{dt}\right]^2 = \frac{m}{2}\left(\frac{dx}{dt}\right)^2[/tex]
For the potential energy, we have
[tex]E_p = \frac{k}{2}(\Delta X)^2 = \frac{k}{2}\left(x + h - L_0)^2[/tex]
But the answer for the potential energy is
[tex]E_p = \frac{k}{2}x^2[/tex]
How is that possible?
There are a couple of things which I am not too sure about. Is it given that x+h is the equilibrium position of the system (ie the system is in equilibrium in the diagram?). If it isnt, then your equation [tex]\Delta x=x+h-L_0[/tex] is not valid.
Even if the system is in equilibrium, why would [tex]\Delta x=x+h-L_0=0[/tex] give you the equilibrium position? That would give you the initial position of the spring when its uncompressed.
Thanks for reply. The problem doesn't tell x+h is the equilibrium position. Well, for vertical spring, I think the equilibrium position is where the force (or acceleration) is ZERO. So I let mg=0 that gives [tex]\Delta X=0[/tex]. Am I doing anything wrong? If so, please help me. Thanks
If you assume cd to be the origin line, then let the distance of the block from the line be y. As such, the potential energy of the block is given by mgy.
Also, the kinetic energy of the block is [tex]\frac{1}{2}mv^2[/tex] where [tex]v=\frac{dy}{dt}[/tex].
Now you have to express v2 in terms of y to get the expression for kinetic energy.
To do this you need express find the force equation of the block in terms of y. This gives you [tex]F=mg-k(x+h-y)[/tex]. From this you can get the value of [tex]\frac{v^2}{2}[/tex] and hence the expression for kinetic energy.
Now you know the expressions for KE and PE. Add them up and you get total energy. At equilibrium, the total energy must be minimum. You can find the minima of the system as the expression for the total energy will be a function of y, which will give you the equilibrium position.
I know its a little long, maybe someone else can come up with a shorter way to do it.
Youre right, the force must be zero, but that is the NET force acting on the block. In this case, the net force is the gravitational force MINUS the force of the spring. That value must be zero, not mg.
Ok, I just update the figure and add the coordinate system. With your hints, I reconsider the solution and note that the problem require to express all answers in terms of [tex]x[/tex].
1) First calculate the kinetic energy, I know that (as you told) the the kinetic energy will be
[tex]E_k = \frac{m}{2}\left(\frac{dy}{dt}\right)^2[/tex]
Since [tex]y=x+h[/tex], so we also have
[tex]E_k = \frac{m}{2}\left(\frac{dx}{dt}\right)^2[/tex]
2) For finding the equilibrium position, we must set the total force to zero, let the unstretched length of spring be [tex]L_0[/tex]
[tex]F = mg - k(x+h - L_0) = 0[/tex]
gives the equilibrium position (measure from the top of the platform) be
[tex]x_0 = \frac{mg}{k}(L_0 - h)[/tex]
3) The elastic potential energy in terms of [tex]x[/tex] is
[tex]E_{ep} = \frac{k}{2}(x - x_0)^2[/tex]
Hope these results are correct :)
FAQ: How to find the equilibrium position and potential energy?
How do you determine the equilibrium position?
The equilibrium position can be determined by finding the point at which the forces acting on the system are balanced, meaning there is no net force. This can be found by setting the derivative of the potential energy function to zero and solving for the position.
What factors affect the equilibrium position?
The equilibrium position is affected by the potential energy function, which is dependent on factors such as the force constant, the distance between particles, and the charges or masses of the particles involved. Additionally, external forces or perturbations can also affect the equilibrium position.
How do you calculate the potential energy at the equilibrium position?
The potential energy at the equilibrium position can be calculated by substituting the equilibrium position into the potential energy function. This will give you the minimum potential energy value at the equilibrium point.
Can the equilibrium position change over time?
In a simple harmonic motion system, the equilibrium position will remain constant. However, in more complex systems, the equilibrium position can change over time due to external forces or changes in the potential energy function.
How does the potential energy affect the equilibrium position?
The potential energy function plays a critical role in determining the equilibrium position. It is essentially a measure of the energy stored in the system at a given position. The equilibrium position is found at the point where the potential energy is at a minimum, indicating that the system is in a stable state.
