How to find the inverse of this equation
In summary: I totally agree. The thrill and exhilaration is in the self-discovery.Everyone on this forum is mean. Instead of just kindly helping, you and those like you have to make sure to go out of their way to get their jabs in. Belittling anyone at any chance they can get. I take it to feel taller? How small you must be. Must be nice to know everything. Next time, if you're going to assist try leaving the sarcasm behind.
aneikei
using this equation
##1-\sqrt{1-x^2/c^2}##
where c = 1 and x = 0.0 - 1.0 the speed of c
for example
##1-\sqrt{1-.886^2/1^2}## = y = 0.5363147619
gives me the y values. How do I find the inverse? How do find for x inputting the values of y?
Thank you.
Mathematics news on Phys.org
Algebraically manipulate your equation until ##x## is expressed as a function of ##y##.
EDIT: For the more general case :You can also use the Inverse/Implicit function theorem to determine when/if the inverse exists. But, as @Svein pointed out, this may be too strong for your case.
Talk about shooting sparrows with a cannon...
Manipulating the formula [itex]y=1-\sqrt{1-\frac{x^{2}}{c^{2}}} [/itex] gives [itex]\sqrt{1-\frac{x^{2}}{c^{2}}}=1-y [/itex] directly. Squaring: [itex] 1-\frac{x^{2}}{c^{2}}=(1-y)^{2}[/itex]. Now solve for x.
aneikei said:
using this equation
for example
Thank you.
Thanks, I already figured it out
##x=\sqrt {2y-y^2}##
This is simply untrue and if this is your perception you need to reconsider how you read the intentions of other people on an internet forum. Also, this is not a regular forum. We will generally not just provide you with an answer and in a schoolwork type question such as this we expect you to put in some effort and show us what you had done. We believe this is much more helpful to help people learn. If you just want to be fed the answer, the forum rules you agreed to when you signed up should have made it clear that this is not the forum for you.
@aneikei, I'm curious as to what exactly you found to be mean. Was it that you weren't given the answer right away? Or was it Svein's comment about "Talk about shooting sparrows with a cannon..."? I think this latter comment was not directed at you, but was directed at WWGD. Svein was saying that there was no need to invoke such heavy mathematics when it was clear that a simple algebraic manipulation would answer your question. Again, please tell us exactly what you found to be mean. Thank you.
Useful for the more general situation that someone may be interested in. My apologies to Anikei if this came of as too high-falutin'. I consider people (like myself) who may read posts and learn something from them. I appreciate if others generalize in this way so I myself can learn.
Aneikei, Svein's reply was addressed at me, not at you.
I apologize gentlemen or ladies. I had a previous post and when I needed an answer in a very particular way. I was browbeaten as to why would I ever do it that way.
When I explained that although I understand the form I want the solution in isn't the "industry standard", but that I need it for my own unique reasons. The post was closed. Effectively slamming the door in my face simply because it was "different".
That arrogance of knowing what's best I've encountered many times. As such, I took the comment on this post a little too personally. Again my apologies.
When I explained that although I understand the form I want the solution this isn't the "industry standard", but that I need it for my own unique reasons. The post was closed. Effectively slamming the door in my face simply because it was "different".
That arrogance of knowing what's best I've encountered many times. As such, I took the comment on this post a little to personally. Again my apologies.
No problem. You may also post a new thread in https://www.physicsforums.com/forums/feedback-and-announcements.19/
To give feedback, if you wish to.
Related to How to find the inverse of this equation
1. How do I know if an equation has an inverse?
One way to determine if an equation has an inverse is to graph it. If the graph passes the horizontal line test, then the equation has an inverse. Another way is to solve for the dependent variable and see if there is a unique solution for every value of the independent variable.
2. What is the process for finding the inverse of an equation?
The process for finding the inverse of an equation involves switching the positions of the independent and dependent variables and solving for the new dependent variable. This can be done by performing inverse operations, such as taking the reciprocal, square root, or logarithm of both sides of the equation.
3. Can every equation be inverted?
No, not every equation has an inverse. Some equations, such as those with horizontal lines or those with more than one solution for the dependent variable, do not have an inverse. It is important to check for the existence of an inverse before attempting to find it.
4. What is the significance of finding the inverse of an equation?
Finding the inverse of an equation can be useful in solving for unknown values, simplifying complex equations, and understanding the relationship between two variables. It can also help in graphing and analyzing functions.
5. Are there any shortcuts or tricks for finding the inverse of an equation?
There are some common methods for finding the inverse of certain types of equations, such as using logarithms for exponential equations or completing the square for quadratic equations. However, these methods may not work for all equations, so it is important to understand the general process for finding inverses.
  • General Math
  • General Math
