ootz0rz
- 3
Hi everyone :) I'm new to the forums, need some help with a homework question I just can't seem to be able to get...
The question as described in my book is as follows:
The mass of the moon is 7.35x10^22 kg. At some point between Earth and the Moon, the force of Earth's gravitational attraction on an object is canceled by the Moon's force of gravitational attraction. If the distance between the Earth and the moon (center to center) is 3.84x10^5 km, calculate where this will occur, relative to the Earth.
Earlier in the book, I am given the mass of the Earth as 5.98x10^24 kg and I am supposed to use that.
What I've got so far (not sure if any of this is correct at all... ):
[tex]F_g = \frac{GMm}{r^2}[/tex]
Where...
[tex]G = 6.67x10^{-11} \frac{Nm^2}{kg^2}[/tex]
M = The larger mass
m = the smaller mass
r = radius
Problem is, we are not given an object being at the L1 point (which I will refer to as X), so it can't be used for that. It can be used however to find the force of gravity from Earth that is acting on the moon at that radius. But anyways, I needed a way to remove the m variable, so I replaced Fg with an equivalent equation:
[tex]\frac{mv^2}{r} = \frac{GMm}{r^2}[/tex]
m and one r cancels out and we get
[tex]\frac{GM}{r} = v^2[/tex]
this however introduces a new unknown variable into, v - being the velocity
However, v can be expressed as
[tex]v = \frac{2 \pi r}{T}[/tex]
therefore [tex]v^2 \Rightarrow v^2 = \frac{4 \pi^2 r^2}{T^2}[/tex]
T is the period it takes to complete one revolution, yet another fun unknown...
at this point we have
[tex]\frac{GM}{r} = \frac{4 \pi^2 r^2}{T^2}[/tex]
Then if we bring r^2 to the left side...
[tex]\frac{GM}{r^3} = \frac{4 \pi^2}{T^2}[/tex]
I could further juggle the equation so it would solve for r...however...I'm not sure what to do with the T variable
That's about as far as I was able to get :/ Any help would be greatly appreciated.
Thank you :)
Where...
M = The larger mass
r = radius
Thank you :)
