How to find the range of a function with square roots?
In summary, to find the range of a function involving square roots, first identify the domain by determining the values for which the expression under the square root is non-negative. Then, analyze the function's behavior as the input approaches the boundaries of the domain. Finally, evaluate the output values to ascertain the minimum and maximum values, which collectively define the range of the function.
arham_jain_hsr
25
Find the domain and range of f(x)=√(9-x^2)
N/A
$$y = f(x) = \sqrt{9-x^2}$$
According to me,
Domain: $$ 9-x^2 \geq 0 \implies (x+3)(x-3) \leq 0 \implies x \in [-3,3] $$
which is correct, but this is how I calculate the range:
$$y = \sqrt{9-x^2} \implies y^2 = 9-x^2 \implies x^2 = 9-y^2$$
Now, since $$ 9-x^2 \geq 0 $$
we get $$9-9+y^2 \geq 0 \implies y^2 \geq 0 \implies y \geq 0$$
$$\therefore y\in[0,\infty)$$
But, the correct answer is supposed to be [0, 3]. Where did I go wrong in my approach? Also, how do I tackle similar problems algebraically?
The reason I think the answer "should" have been correct is that I think that y is only restricted by values of x. So, if we use the domain as a constraint on y, we should get the range of y. But, somehow that yields the wrong answer...
In general, an implication is not reversible. If you conclude that ##\Rightarrow \ f(x) \ge 0##, then that does not mean that the range of ##f## is ##[0, \infty)##. For example, if ##f(x) = 1##, then ##f(x) \ge 0##, but the range of ##f## is only the single point ##1##.
The range is precisely the set of possible functions values. Not any set which contains those function values.
PS to emphasise the point, for any function you can conclude that ##\Rightarrow \ f(x) \in \mathbb R##.
Likes Delta2 and MatinSAR
PS if the range of ##f## is ##[0, \infty)##, the you should be able to find ##x## such that ##f(x) = 4##. Is that possible?
My idea was that there is only one condition on what y is like. And, therefore after applying that condition, whatever interval we get for y should be the required range.
Like, in my case, I thought the range of y is [itex][0, \infty)[/itex] because I didn't know anything else about y (other than its relation to x) that could possibly narrow the range down.
I supposed that by "using" [itex]9 - x^2 > 0[/itex] to find my answer, the interval of y that I get would be such that it complied with [itex]9 - x^2 > 0[/itex].
You know a lot more about ##y## than it's just any non-negative number.
Exactly! Or, sketch a graph of the function.
Likes MatinSAR
Homework Statement: Find the domain and range of f(x)=√(9-x^2)
Relevant Equations: N/A
You can also start from ##-x^2 \leq 0 ## then try to create ##f(x)## on one side of this inequality the other side will help you find the range.
But, why does my approach yield the wrong answer?
Maybe if you set ##y=f(x)##, square both sides, you'll obtain a revognizable expression that will help you determine the range.
I already explained that. The range is the precise set of values that ##f(x)## can take. You didn't look for the precise set of values. You just noted that the range is a subset of ##[0, \infty)## and then stopped there. You didn't use the other information about ##f##.
PS to take an example. Find the range of the function ##f(x) = x^2 + 1##?
Your solution: ##f(x) > 0##, so the range is ##[0, \infty)##.
My solution: the range is precisely ##[1, \infty)##.
A circle at origin with radius 3 units?
Precisely.
WWGD said:
Precisely.
Oh, so, since it represents a circle, y may vary from -3 to +3. We are getting this because we lost the information that y must be positive in the process of squaring both sides. So, reconsidering that, we get the range [0, 3].
Well, I think my confusion can be better stated as follows:
Why, if I derived my answer from the fact that "[itex]9 - x ^ 2[/itex] should be greater than equal to [itex]0[/itex]", am I getting an answer that allows values of [itex]y[/itex] for which [itex]x[/itex] is greater than [itex]3[/itex]?
Well, ##9-x^2 \geq 0 ## doesn't exclude values for ##x## in ##[-3,0]##.
I already explained that. You simply showed that ##y \ge 0##. That's true, but not the whole story. I'll repost post #2, which you either didn't read or didn't understand.
Likes MatinSAR
Oh, ok. Now, I understand. As it appears, my flaw here is pretty silly. So, basically, to find the domain, I "used" the fact that [itex]y^2 = 9 - x^2 \geq 0[/itex]. That's fine, because the fact that [itex]y^2[/itex] should be greater than [itex]0[/itex] puts a constraint on what the possible values of [itex]x[/itex] can be.
Now, here, I am trying to use the same piece of information [itex]y^2>0[/itex] (which due to the substitution, I was illusioned to think is something "novel") to find the range. But, the problem is that this piece of information doesn't restrict the values of [itex]y[/itex] to what is supported by the possible values of [itex]x[/itex].
And, hence unless and until I "constrain" the values of [itex]y[/itex] as described by the question, I won't get the correct range. For example, if I'd rather begun from [itex]x^2 = 9 - y^2 > 0[/itex], therefore restricting the values of [itex]y[/itex] "based" on the possible values of [itex]x[/itex], I'd indeed have arrived at the correct range for this relation. (Of course, limiting the values of y to positive real numbers only)
Thank you so much for helping me understand 🙏 @PeroK @MatinSAR @WWGD @DaveE :)
Likes MatinSAR, DaveE and WWGD
I'm not sure you understand, yet. ##y^2##, merely by virtue of being the square of a real number, will always be greater than or equal to zero. The same is true of ##x^2##. This means that the largest value of ##y^2## is 9, hence ##y \in [-3, 3]##. But since the original equation is ##y = \sqrt{9 - x^2}##, that means the smallest value of y is 0.
Likes MatinSAR and SammyS
I agree with @Mark44. I would have noted that:
$$0 \le \sqrt{9-x^2} \le 3$$Informally, you can then conclude that the range of ##f## is ##[0,3]##. Technically, however, you still have to show that for any ##y \in [0,3]## you can find ##x## such that ##f(x)=y##.
I'm sorry. I don't get you. Isn't that exactly what I said as well?
You wrote ##y^2 > 0## which really should be ##y^2 \ge 0##, and this has nothing to do with any substitution, but only due to the fact that the square of a real number has to be nonnegative. Then you made a diversion to another equation, ##x^2 = 9 - y^2##, and seemed to miss the fact that ## 0 \le y = \sqrt{9 - x^2} \le 3##, which gives you the range.
As far as the domain, ##9 - x^2 \ge 0 \Rightarrow -3 \le x \le 3##.
Likes arham_jain_hsr, MatinSAR and PeroK
Noted. Thanks for pointing that out.
FAQ: How to find the range of a function with square roots?
How do I find the domain of a function with square roots?
To find the domain of a function with square roots, you need to ensure that the expression inside the square root is non-negative. Set the expression inside the square root greater than or equal to zero and solve for the variable. The solution will give you the domain of the function.
How do I determine the range of a function with square roots?
To determine the range of a function with square roots, start by finding the domain. Then, analyze the behavior of the function within this domain. Consider the minimum and maximum values of the square root expression, and how they affect the overall function. This will help you identify the possible output values, which constitute the range.
Can I use a graph to find the range of a function with square roots?
Yes, graphing the function can be a helpful way to visualize the range. Plot the function on a coordinate plane and observe the y-values that the function attains. The set of all these y-values will give you the range of the function.
Are there any specific techniques to simplify finding the range of a function with square roots?
One useful technique is to isolate the square root term and then square both sides of the equation to eliminate the square root. This can make it easier to analyze the function. Additionally, consider the endpoints and critical points within the domain to identify the minimum and maximum values of the function.
What should I do if the function with square roots is more complex?
If the function is more complex, consider breaking it down into simpler parts. Analyze each part individually, and then combine the results to find the overall range. You may also use calculus techniques, such as finding the derivative to identify critical points and determine local minima and maxima.
