How to find the specific heat capacity of a mixture?
In summary, the conversation discusses how to find the specific heat capacity of water-solute mixtures and determine the difference from that of pure water. The speaker has the mass and temperature change data, but is missing Q and C variables. They consider using an electric stove with a known wattage as Q, but Chet advises using a control experiment with pure water to accurately measure the heat output of the stove.
timsmith98
For my physics IA, I am finding the specific heat capacity of water-solute mixtures and finding how the specific heat differs from that of just water alone. I have the mass of the mixture, for example baking soda and water was 914.75g and changed 175.8 degrees Fahrenheit in 9.5 minutes. I just need to know the specific heat capacity along with Q in the equation.
I can't find the solution because I am missing two variables: Q and C. If there's any way to find either solution, please let me know. Thank you!
Do you know the imposed heating rate?
I'm not 100% sure what you mean by this. Can you give me an example please? Thanks for the help!
Your'e using a heater, right? What is the power input of the heater?
I was using a gas stovetop set on high to heat it from solid form until it boiled.
Too bad. Game over. You need to know the rate at which you are adding heat. You might be able to do this by first measuring how fast the water heats up when the stove is at full blast with pure water in the pot, and then use this to scale the heat capacity in your solutions. But, some of the heat also goes into the pot.
Chet
Chet
So if I were to redo the trial with an electric stove that puts out 2500 watts, would it be easier to find the specific heat?
Yes, providing you could make sure that all the heat goes into the water and pot and none escapes to the room and stove. The difference you are trying to detect is very tiny, and the slightest error in the heat flow to the water can lead to very inaccurate results. This is really a very sensitive measurement that really needs to be made under carefully controlled laboratory type conditions.
Chet
BTW, the purpose of your experiments is to determine C, which is the specific heat capacity.
Yeah but I'm having trouble finding C because of my lack of Q. Do you know whether or not I could use the wattage of an electric burner as Q if I decided use an electric stove that puts out 2500W?
Subject to what Chet said in Post #8. You might have to arrange an experimental control, whereby you use the electric stove to heat up a known quantity of pure water.
You can measure the temperature change of the water and compare your calculation of the heat output by the stove with the amount of heat absorbed by the pure water.
Related to How to find the specific heat capacity of a mixture?
1. How do I determine the specific heat capacity of a mixture?
To determine the specific heat capacity of a mixture, you will need to know the mass and initial temperature of the mixture, as well as the specific heat capacities of each component in the mixture.
2. What is the formula for calculating specific heat capacity of a mixture?
The formula for calculating specific heat capacity of a mixture is: Cm = (m1C1 + m2C2 + ... + mnCn) / (m1 + m2 + ... + mn), where Cm is the specific heat capacity of the mixture, m1-mn are the masses of each component, and C1-Cn are the specific heat capacities of each component.
3. How do I find the mass of each component in a mixture?
To find the mass of each component in a mixture, you can use a balance or scale to measure the mass of the entire mixture, then use the percentage of each component in the mixture to calculate the individual masses.
4. Can I use the specific heat capacity of pure substances in a mixture calculation?
Yes, you can use the specific heat capacities of pure substances in a mixture calculation. However, it is important to note that the specific heat capacity of a substance may change when it is in a mixture compared to when it is in its pure form.
5. How do I handle phase changes in a mixture when calculating specific heat capacity?
When calculating the specific heat capacity of a mixture, it is important to consider any phase changes that may occur. If there are phase changes, you will need to use the specific heat of fusion or vaporization in your calculation, depending on the type of phase change that occurs.
