How to find the turns ratio between the primary and secondary coils.
  • Thread starter nontradstuden
  • Tags
    Coils Ratio
In summary, to find the turns ratio across the transformer for a spark to be given off at points AB, you can use the equation N_p /N_s = V_p / V_s = I_s /I_p. The potential between points A and B must be equal to the dielectric breakdown strength of air multiplied by the distance AB.
nontradstuden
54
Find the turns ratio across the transformer such that a spark is given off at the points AB. The distance from point A to point B is 5.00 mm.
AB is the distance across the secondary coil.
The frequency and voltage of the primary coil is given.
I don't know where to start. I got it wrong. I was given the answer, but not the solution to the problem. Could I get some help on where to start?
What potential must exist between points A and B in order for a spark to jump the gap?
gneill,
Thanks for helping. I honestly don't know what I was thinking. I knew the potential of the secondary coil had to be the dielectric constant of air multiplied by the distance AB.
nontradstuden said:
gneill,
I think you mean the dielectric breakdown strength of air :smile:
As a scientist, the first step in solving this problem would be to gather all the necessary information. This includes the distance between points A and B, the frequency and voltage of the primary coil, and any other relevant data.
Next, I would use the equation N_p /N_s = V_p / V_s to find the turns ratio between the primary and secondary coils. This equation states that the ratio of the number of turns in the primary coil to the number of turns in the secondary coil is equal to the ratio of the primary voltage to the secondary voltage.
To find the number of turns in the secondary coil, we can use the distance AB and the known frequency of the primary coil. The formula for calculating the number of turns in a coil is N = (L * f)/c, where N is the number of turns, L is the length of the coil, f is the frequency, and c is the speed of light. In this case, L is equal to 5.00 mm and c is a constant value.
Once we have the number of turns in the secondary coil, we can use the turns ratio equation to find the number of turns in the primary coil. This will give us the turns ratio between the two coils.
In conclusion, to find the turns ratio between the primary and secondary coils, we need to gather all the necessary information, use the turns ratio equation, and calculate the number of turns in the secondary and primary coils.
Related to How to find the turns ratio between the primary and secondary coils.
1. How do you measure the turns ratio between the primary and secondary coils?
The turns ratio can be calculated by dividing the number of turns in the secondary coil by the number of turns in the primary coil.
2. Can the turns ratio change over time?
The turns ratio can change if there is a change in the physical characteristics of the coils, such as the number of turns or the material used. However, if the coils remain the same, the turns ratio will remain constant.
3. What is the significance of the turns ratio in a transformer?
The turns ratio determines the voltage and current ratio between the primary and secondary coils in a transformer. It is an important factor in determining the efficiency and functionality of the transformer.
4. How can you alter the turns ratio in a transformer?
The turns ratio can be altered by changing the number of turns in the coils or by using a different material for the coils. This can be done during the design and construction phase of the transformer.
5. Is there a specific formula for calculating the turns ratio?
Yes, the turns ratio can be calculated using the formula Ns/Np = Vs/Vp, where Ns is the number of turns in the secondary coil, Np is the number of turns in the primary coil, Vs is the voltage in the secondary coil, and Vp is the voltage in the primary coil.
