How to find the work on an object on an inclined plane pulled with a rope
In summary, the user is trying to determine the work done by a 20N force whenpulling an object at an angle. They use the work done by the force to calculate the work done by the object.
Kelvin Andersen
g = ##10m/s^2##
##\sqrt{3}## = 1.7
Determine work by the 20N force
for an inclined plane:
W = ((F+mgsin30)-(mgcos30)μ)s -> (Fx-ff)*s
for object pulled with angle:
W= (Fcos60-(mg-Fsin60)μ)s -> (Fx-ff)*s
W= ((Fcos60+mgsin30)-(mgcos30-Fsin60)μ)s
(W= (Fx-ff)*s, Fx=Fcos50+wsin30, ff=(wcos30-Fsin60)*μ)
What I did to get the equation above:
for Fx:
Based on inclined plane equation, Fx=F+wsin30
However, since F is angled, F becomes Fcos60
so Fx=Fcos60+wsin30
for ff:
Based on angled force equation, ff=w-sin60
I change w -> wcos30
so ff=wcos30-Fsin60
sin30=3/s -> s=6
W= (((20)(cos60)+(3)(10)(sin30))-((3)(10)(cos30)-(20)(sin60))(0.2))(6) (inputting number based on the above)
by using √3 = 1.7
W= ((10+15)-(25.5-17)(0.2))(6)
W= (25-1.7)(6) = 139.8 Joules (don't know if correct or not)
Kelvin Andersen said:
g = ##10m/s^2##
##\sqrt{3}## = 1.7
Determine work
W= (((20)(cos60)+(3)(10)(sin30))-((3)(10)(cos30)-(20)(sin60))(0.2))(3)
by using √3 = 1.7
W= ((10+15)-(25.5-17)(0.2))(3)
W= (25-1.7)(3) = 69.9 Joules (dont' know if correct or not)
Work done by which force you haven't mentioned
g = ##10m/s^2##
##\sqrt{3}## = 1.7
by using √3 = 1.7
W= (25-1.7)(3) = 69.9 Joules (don't know if correct or not)
The big problem with what you have posted is that you haven't explained at all what calculations you are carrying out. The line I've underlined is almost impossible to parse.
In any case, your solution looks wrong to me.
Try to explain what you are calculating and why.
edited
edited
It's still incomprehensible to me.
How, in general, do you calculate the work done by a force?
Related to How to find the work on an object on an inclined plane pulled with a rope
1. How do you calculate the work done on an object on an inclined plane pulled with a rope?
The work done on an object on an inclined plane pulled with a rope can be calculated using the formula W = Fdcosθ, where W is work, F is force, d is distance, and θ is the angle between the force and the displacement.
2. What is the role of the angle of inclination in calculating the work done on an object pulled with a rope on an inclined plane?
The angle of inclination is important in calculating the work done because it affects the amount of force needed to move the object. A steeper incline requires more force, resulting in more work being done.
3. How does the weight of the object affect the work done on it on an inclined plane pulled with a rope?
The weight of the object does not directly affect the work done on it. However, it does contribute to the force needed to move the object, which in turn affects the work done.
4. Is the work done on an object on an inclined plane pulled with a rope always positive?
No, the work done on an object can be either positive or negative depending on the direction of the force and the displacement of the object. If the force and displacement are in the same direction, the work done is positive. If they are in opposite directions, the work done is negative.
5. How can the work done on an object on an inclined plane pulled with a rope be increased?
The work done on an object can be increased by either increasing the force applied to the object or increasing the distance over which the force is applied. This can be achieved by using a steeper incline or a longer rope.
16K
